Top 5 YouTube to MP3 Downloaders for Android
Summary: Are you looking for an Android YouTube to MP3 downloader? Or do you want to download YouTube to MP3 for playing on your android phone? Here are top 5 best YouTube to MP3 downloaders for Android.
Listening to music on YouTube has its charm. However, it can also be a source of hassle at times, especially when you wish to use your phone for other things as you listen to music in the background. Individuals who don’t wish to buy music will find themselves at a crossroad. Should they undergo the hassle of using their phone only to stream videos or pay the price?
The good news for you is that there is a middle ground. You can easily find a YouTube MP3 Downloader for Android. Some of them are even free of cost. Whether you wish to get yourself a YouTube to MP3 converter for Android for free download or pay a small price, you can rest assured that you don’t necessarily have to go through the hassle of using YouTube to listen to anything.
Here is the best YouTube to MP3 downloader for Android.
Videoder
This YouTube MP3 downloader app for Android is free. However, it is not available on Google Play and has to be downloaded directly from the site. The best thing about this video downloading app is that the interface is simple and easy to understand. It even lets you use YouTube within the app.
Hence, you are not required to copy paste any links. You just need to open the required video within the app and use the converter to convert it in the MP3 format on the go. While the app is free of lag and can be used to download videos on websites like Facebook and Instagram, all of it does come at a cost of advertisements.
YouMp34
YouMp34 is yet another quality YouTube MP3 downloader Android app for free. Rather than merely allowing you to convert videos to MP3 format, it also lets you download the music in MP4 formats. The download and conversion are very simple and quick. All you need to do is look for the video you wish to download and click on it to download it in either of the two formats.
InsTube YouTube Downloader
When it comes to delivering a fast and user-friendly experience, no YouTube MP3 downloader for Android can match the value provided by this app. It can be downloaded via the official site and delivers high speed and a UI that lets you manage all your downloaded files in a single place. The fact that it supports all types of resolutions, ranging from HD to 4K, has made it a likely choice of many.
The downloader can be used to download YouTube files in an array of formats, ranging from MP3 to M4A. Since it supports over 40 websites, you are not limited to YouTube to download music on your Android phone. While this app is free, you will be plagued with ads that you can’t avoid.
Syncios YouTube Downloader
By downloading Syncios YouTube Downloader, you can save your entire playlist offline by converting it into MP3 format. The download process is user-friendly and easy to understand. Apart from YouTube, the app can also be used to find and download music from more than 100 sites.
You can also choose to compress the quality of the video as the app allows you to select the format as well as the quality of the downloaded content. It is a computer app but it can sync the MP3 file to your Android phone.
The business model of Syncios is also makingmoney from advertisements. Hence, you can expect pop-up ads and you might not be able to avoid them. However, the free element of the downloader may make it worth it.
KeepVid
All the good features of KeepVid are available in the premium version of the app, but a free version is also available for those who don’t want to invest in a YouTube downloader. This version is very basic but gets the job done to some extent.
The premium version allows you to download all sorts of videos, regardless of their quality. Moreover, since YouTube can be launched within the app, you can easily find the video and download it without wasting much time on transferring links. Compared to the free options, this premium downloader is compatible with 10,000 websites. Hence, you can bid the need for other downloader apps goodbye. Additionally, the speed of the app is thrice of what is offered by free apps.
However, the fact remains that all the features come at a price. In the free version, you won’t be able to download from the same exhaustive lists of websites. Also, entire files might not be downloaded. Only a fraction of the video will be converted. Still, it is the best premium YouTube MP3 downloader app for Android.
If you are looking for a YouTube to MP3 converter for Android for free download, the best option is Videoder because of its interface and convenience. However, the other options are also worth a try.
If you are looking for a way to quickly download and convert YouTube videos to MP4 and MP3 formats on your desktop, you can try DVDFab YouTube Video Downloader and DVDFab Video Converter. The former program allows you to quickly download all sorts of YouTube videos, regardless of the format. The latter lets you convert the video you downloaded to whatever format you like. Together, they deliver the perfect package.
However, this is not a viable option for Android. They can be used if you are willing to download and convert files on your desktop and transfer them to your Android device. If you plan on using the DVDFab YouTube Video Downloader, make sure you install the latest DVDFab 10 since this is a recent addition and only works on updated versions.
Go ahead and download YouTube videos on your Android phone and stop relying on online streaming to listen to music.
