Review of Xilisoft Video Converter Ultimate and Its Best Alternative
Summary: Xilisoft Video Converter Ultimate, as a powerful and efficient converter product, has gained a lot of popularity. This passage will give a detailed and comprehensive introduction to its functions as well as other outstanding video converters.
Xilisoft Video Converter Ultimate Review
Operating system: Windows, Mac
Price: $59.95
Xilisoft Video Converter Ultimate is the best version of Xilisoft Video Converter and is considered as one of the best video converters, due to its miscellaneous functions compatible with all kinds of devices.
Features
- High-definition and fast conversion
Equipped with edgy HD video conversion technology, Xilisoft Video Converter Ultimate is able to convert all kinds of video and audio formats as well as HD video formats such as H.264 and MPEG-4 video.
You won’t worry when your device's media player couldn't recognize the video or audio format. Armed with Xilisoft Video Converter Ultimate, you could feel free to play videos on your multimedia devices, including iPhone, iPad, iPod, Xbox, PS3, PSP.
- Wonderful video editor
The built-in video editor enables users to make videos more attractive and appalling. you can clip/merge/split files, add watermarks/subtitles/soundtracks, apply special effects and crop video. All the basic editing functions can be found in Xilisoft Video Converter Ultimate.
- Personalized conversion files
Have you ever felt annoyed by the files in confusion? With Xilisoft Video Converter Ultimate, there is no need to worry about that problem any longer.
It supports the conversion files optimization function, which means you are able to customize an existing profile classified by device types, in this way you could easily find your target files.
Cons
- The trial version only includes limited functions compared with its full version.
- Its price is a little bit higher compared with other similar products.
Xilisoft Video Converter Ultimate aims to satisfy the needs of both novices and professionals. Its arranging method enables users to deal with video files: all the functions lay in one interface, hence, there is no need to search for a sub-menu to complete the video edition process. What’s more, there are two sets of output settings, one for novices to provide simple and adjustable options and another offers advanced choices to edit videos. If you have related needs, Xilisoft Video Converter Ultimate is worth trying.
A Better Choice - DVDFab Video Converter Pro
Price: $29.99
If you are searching for the best video converter, DVDFab Video Converter Pro is certainly one of the best choices. With more than 17-year experience, DVDFab Video Converter Pro has gained popularity increasingly due to its powerful functions.
It is able to convert video (up to 1080p/4K/5K/8K) from one format to another, and convert video to mainstream audio formats, playable on mobile devices and home theater.
Features
- Convert Video (up to 1080p/4K/5K/8K) or Audio between 1000+ Formats
No matter what video or audio formats, be it MP4, WMA or MP3, DVDFab Video Converter Pro could convert all the popular formats. HEVC/H265, 3D, 8K, 4K, 10bit, 12bit, and Passthrough are available to deliver quality conversion.
During the process of conversion, the metadata information of the file sources will be downloaded automatically to apply to the target videos.
Besides, DVDFab Player 6 will help you build, organize and manage your local video library. All your videos will be in line according to their release time, name, genre, cast, or you can also set your own settings.
- Customized Audio & Video Parameters Make Everything Easier
The users have complete control over the disposal of your output videos. You can trim long video files into small segments for better uploading to popular platforms such as YouTube and Instagram.
Besides, you could choose to add subtitles to make your videos more attractive and understandable. What’s more, it can be applied to stitching various clips together. All the functions you need lay in DVDFab Video Converter Pro. Only one program is enough.
- Built-in Video Editor Offers Multiple Choices
The powerful functions provide various chances to make your videos better. Its simple, intuitive interface enables you to make attractive content no matter you are a beginner or a professional.
Adding a premium opener or background music is all ready for your creation. Additionally, you could adjust brightness, contrast and saturation to enhance video quality.
What’s more, you could also gain access to blending videos, audio and images into stunning audiovisual masterpieces. There are other interesting and useful functions for you to explore. Act now to raise highlights.
- Speedy Conversion with Multiple H/W Technologies
DVDFab Video Converter Pro owns a simple and intuitive UI to display the utmost user experience. With the help of multi-threading, multi-core, the latest NVIDIA CUDA, and Intel Quick Sync, DVDFab Video Converter Pro is capable finish any video or audio conversion task in batch at 30X faster than normal speed.
How to Use DVDFab Video Converter Pro?
- Choose Your Wanted File
Launch DVDFab Video Converter Pro and go for the tool you need. For example, the Video Converter tool. Then drag or drop your wanted file, or simply click the “+” button to find the file.
- Set Proper Parameters
After clicking the Choose Other Profile from the drop-down menu, you will see Format and Device options. You could select one proper format and device for videos. Besides, if you need to set other advanced parameters, you could edit videos in the built-in Edit function.
- Wait for Final Results
This is the final step of the conversion process. All you need to do is click the Start Button and wait a few moments. DVDFab Video Converter Pro software will immediately convert video to the target profile you have chosen, and provide you with detailed progress details during the process. Additionally, you could also choose to pause, continue or cancel.
Other Good Choices
DVDFab Online Video Converter
Operating system: online
Price: Free
DVDFab has been considered as one of the most reliable and best video converters online free. It’s famous for its mature system, stable quality, competitive price, and miscellaneous functions. DVDFab online video converter supports 10 files each day, and the size of a file is up to 200MB.
- Popular formats supported
No matter you need MP4, MKV, VOB, WMV, FLV, MOV, DVDFab could cover all these formats. You can choose to convert the audio or video file to the most popular formats, no need to be bothered by the conversion of multiple formats, DVDFab can solve all these kinds of problems.
- Fast and easy
Have you ever waited for the online video conversion for hours? Have you ever been perplexed by the complicated instruction manual? If yes, you will never need to worry from now. Armed with DVDFab, you won’t suffer from that anymore. After you finish the first two steps above, all you need to do is wait for the final results in just a few minutes.
- Excellent quality
If you are concerned about the video quality, DVDFab must be your priority. It adopts high-quality video processing algorithms to ensure no quality losses in the process of converting. Whether you are a Mac or Windows, iPhone or Android user, you can compress the large video files into smaller sizes without any evident reduction in the definition.
- Cloud conversion
All the conversion tasks will be conducted in the cloud, therefore, the users don’t need to install any apps, which won’t occupy computer hard disk and computing power. Besides, it is more convenient for you to finish the missions.
Freemake Video Converter
Price: Free/Various
For beginners, Freemake Video Converter is definitely one of the best options, for its intuitive interface and a wide range of mainstream profile choices.
On the top of the interface, it provides some choices to add video files and users could choose the output formats including MP3 and MP4. The final files are compatible with Apple and Android devices, PlayStation and Xbox consoles, Samsung TVs and both DVD and Blu-ray discs.
Cons
- Low conversion speed
If you don’t pay for the updated version, the whole conversion process will last for a long time, especially in the first 20 minutes. Although it will process video files at a fast speed, this function doesn’t appear in a distinct place which may lead to frequent ignorance.
- Annoying ads and watermark
In the process of conversion, there will appear a pile of pop-up advertisements, which greatly impacts the user experience. Besides, your videos that are converted by Freemake Video Converter will have a watermark.
Which is the best video converter?
As the demands of video converters grow, there appears a great number of excellent products in the market. Having made a comprehensive comparison, DVDFab Video Converter Pro is the best video converter for its considerate design and powerful functions. More importantly, DVDFab always conducts user-oriented principles and keeps trying to provide better products.
Is DVDFab safe?
DVDFab DVD Copy is safe and easy to use on both Windows and Mac. It can remove encryption embedded in DVDs like APS, CSS, CPRM, Cinavia automatically. This DVD decrypter lets you copy DVDs to an ISO file, folder, or another blank DVD disc.
Xilisoft Video Converter Ultimate serves as a professional video converter as well as an audio converter, covering all the basic functions. Its related products Xilisoft DVD Ripper is worth having a try. What’s more, this passage also recommends other excellent products: DVDFab DVD Converter Pro, its online version and a free video converter. Hopefully, this post is of help to you.
