The Best Free Way to WMA to MP3 2025[Windows/Mac/Online]
Summary: WMA to MP3 on Windows, Mac, Online. There is the easiest and fast way to convert WMA to MP3 without any limit and you don’t need to pay one cent.
Many people ask “How to convert WMA to MP3 Windows Media Player” or “Can I convert WMA to MP3 in Windows Media Player”? Here in order to save you from detour, I want to make it clear that Windows Media Player cannot convert WMA to MP3 independently, which means you have to install another third-party tool to collaborate with this player. Then if WMA to MP3 can be completed with just one software, why seek two? So in this post I will introduce some best free WMA to MP3 converters to help you convert WMA to MP3 easily on Windows, Mac and Online.
1. Why convert WMA to MP3?
Which is better, WMA or MP3? It depends on where you are going to use such files. As a Windows audio format developed by Microsoft, WMA is supported by Windows Media Player, VLC Media Player, MPlayer, RealPlayer, while it is not compatible with iPhone, iPod, iPad and some MP3 players. Secondly, WMA files are relatively small compared with MP3 files. Third, MP3 music takes on better sound quality than WMA audios. So convert WMA to MP3 or not based on your needs.
2. How do I convert a file from WMA to MP3?
Here I want to recommend some offline and online WMA to MP3 converter for your free trial. No matter you are a Windows user, Mac lover or “uninstall any software supporter”, there are all clear and easy access to convert WMA to MP3.
(1) DVDFab Video Converter Pro (Windows 10/8.1.8/7)
This WMA to MP3 converter is filled with three programs, including Video Converter, Toolkit, as well as Video Editor. You can enjoy a free trial up to 30 days. If you want to convert WMA to MP3, choose either Video Converter or Toolkit. Here is how to convert MMA to MP3 with two of them.
WMA to MP3 with Video Converter
DVDFab Video Converter, a batch WMA to MP3 converter, supports 44 kinds of source file formats which I have listed in the chart below. Besides WMA to MP3, you can also convert other formats of files to MP3 format. Apart from audio to audio conversion, this WMA to MP3 converter also backs video to audio and video to video conversion and the operational steps are similar. Here, let me take WMA to MP3 conversion as example to show you how to use DVDFab Video Converter Pro.
Supported Source File Formats: 44 kinds |
3GP |
3G2 |
AVI |
DIVX |
FLV |
F4V |
M2TS |
MTS |
MP2 |
MOV |
MP4 |
M4V |
M4A |
MPEG |
DAT |
MKV |
OGM |
RMVB |
RM |
TS |
TP |
VOB |
WMV |
WTV |
WMA |
WAV |
ASF |
DVR-MS |
MP3 |
APE |
FLAC |
WEBM |
AAC |
AC3 |
AIF |
AIFF |
CUE |
AU |
ARM |
OGG |
DPE |
MKA |
MPA |
RA |
Steps on how to convert WMA to MP3 with DVDFab Video Converter Pro:
- Get this WMA to MP3 converter free download on Windows
- Launch it and click the program of Video Converter on the left
- Select the module of Converter when you come to main interface of Video Converter
- Click the “+” icon or Add from Local/Mobile to import your file to this WMA to MP3 converter
- Click the option of Choose Other Profile in line with Info
Then supported output audio formats will show up on another small panel, including AAC, AC3, AIFF, APE, AU, DTS, EAC3, FLAC, M4A, MKA, MP3, OGG, COPY, WAV, and WMA
- Click MP3 in order to convert WMA to MP3
- Set the output destination: Mobile, Folder, YouTube, Vimeo or Facebook
- Click the button of Start to convert WMA to MP3
This is how to change WMA to MP3 with the Video Converter module in DVDFab Video Converter Pro. Besides using this program to convert WMA to MP3, you can also convert WMA to AAC, AC3, AIFF, APE, AU, DTS, EAC3, FLAC, M4A, MKA, OGG, COPY, WAV, and WMA formats. In order to convert WMA to MP3 Windows, just download DVDFab Video Converter Pro and click the module of Video Converter. In order to convert WMA to MP3 Mac, just search and install DVDFab Video Converter, instead of DVDFab Video Converter Pro.
WMA to MP3 with Toolkit
After launching DVDFab Video Converter Pro on your computer, click the program of Toolkit, another music converter from WMA to MP3. This free software to convert WMA to MP3 accepts 17 source file formats, as listed below. It is easier to convert WMA to MP3 with Toolkit, compared with DVDFab Video Converter. Let’s explore how to use it to convert WMA files to MP3 together.
Supported Source File Formats: 17 Kinds |
M4A |
M4B |
WMA |
WAV |
MP3 |
APE |
FLAC |
AAC |
AC3 |
AIF |
AIFF |
AU |
RAM |
OGG |
MKA |
MP2, RA |
Steps on how to convert WMA to MP3 with Toolkit:
- Click Converter button under Audio Tools
- Import your WMA file by clicking the + icon
- Set the output audio format as MP3
- Adjust the audio codec, channels, bit rate, sample rate based on your need
- Decide where to store your converted WMA to MP3 file
This is how to turn WMA to MP3 with the Toolkit module in DVDFab Video Converter Pro. Besides WMA to MP3, you can also convert WMA to AAC, AC3, FLAC, and M4A formats. Which freeware WMA to MP3 do you prefer, DVDFab Video Converter or DVDFab Toolkit?
How do you think of this music converter from WMA to MP3 - DVDFab Video Converter Pro, one freeware offering two ways for you to convert WMA to MP3? Besides the module of Video Converter and Toolkit, another module in this WMA to MP3 converter named Video Editor Edit also deserves your attention, which allows you to add audio, text, filters, overlays, transitions, mosaic, etc. to your file. Most importantly, you can try DVDFab Video Converter Pro free up to 30 days without limit.
(2) WMA to MP3 Converter Free Online
Is there any way to convert WMA to MP3 without installing any audio converter on a computer? YES. Turn to an online converter WMA to MP3 for help, such as ZamZar, CloudConvert, Convertio, Online Audio Converter, Online-Convert, and among others. If you know how to convert WMA to MP3 in one online software, you will know how to do that on all online WMA to MP3 converter.
How to convert WMA to MP3 with ZamZar:
- Come to the official website of this online WMA to MP3 converter software
- Add WMA file(s) to this music converter from WMA to MP3
- Choose MP3 as the output audio format
- Click the button of “Convert Now” to convert WMA to MP3
Follow the same way to convert WMA to MP3 using other free music file converter WMA to MP3. Here, no need to installing any software on your computer is a great strength, but a long time for WMA to MP3 conversion is a big problem. You should be patient if some online WMA to MP3 converter works slowly to process a file.
Here are where you can add WMA files and convert WMA to MP3 in each free WMA to MP3 converters.
- ZamZar: Import WMA files from computer less than 50MB
- Convertio: Choose WMA music from computer, Google Drive, Dropbox or by URL less than 100MB
- Online Audio Converter: Open files from computer, Google Drive, Dropbox or by URL
- CloudConvert: Add WMA audios from computer, Google Drive, Dropbox, OneDrive or By URL
- Online-Convert: Select files from computer, URL, Dropbox, and Google Drive
3. What is the best WMA to MP3 converter?
Now, according to different operating systems and will to install third-party software, I have given some advice on which WMA to MP3 converter you should use.
- Windows Operating System (Convert WAM to MP3 on Windows 10/8.1/8/7)
- Free no limit in 30 days
- Support batch convert WMA to MP3
(2) DVDFab Video Converter
- Windows or Mac Operating System
- Convert audio to audio, video to video, video to audio in mainstream formats
(3) ZamZar, CloudConvert, Convertio, Online Audio Converter, Online-Convert -
- Online WMA to MP3 Converter
- No need to install any software
- Limit on file size and WMA to MP3 conversion speed
4. Conclusion
After reading this post, have you had a full picture of how to convert WMA to MP3 with a free audio converter? Which one is the best WMA to MP3 converter in your mind? Choose a program to convert WMA to MP3 based on your operating system and will to install third-party software. Forget how to convert WMA to MP3 on Windows Media Player (WMP) since you need both WMP and another software. As to how to convert WMA to MP3 iTunes, someone told it is possible for iTunes to load WMA, someone said When WMA is not DRM-protected, iTunes can be used to convert WMA to MP3; when WMA is DRM-protected, iTunes cannot. I think there is no need to waste time in this application. It is worthwhile to choose a clear and easy way to convert WMA to MP3.
Other Articles You May Like:
Unblur Photos Free and Fast [Remove Blur from Photo]
Increase Video Resolution with Video Quality Enhancer
Denoise [Noise Reduction from Video and Noise Removal in Audio]
HEVC Codec Extension Free Download and HEVC Codec Players Windows/Mac
