Top 6 Converters to Convert DAV to MP4 and Other Formats 2025
Summary: Encountering issues with your DAV to MP4 conversion process? We have solutions! Read this article to find out how to retain perfect video quality while converting from DAV to MP4 and other formats.
Convert videos from one format to another like DAV to MP4
Support 1000+ video-to-video and audio format conversion
Compress high-quality video and audio without quality loss
Embedded with editing functions like cropping, effect, and watermarks
Introduction
DAV stands for Digital Audio Video, and it is a proprietary format used by some security cameras and CCTV systems. It is primarily used to store surveillance footage, and it is not compatible with most media players or editing software.
Converting DAV to MP4 can be a bit tricky, but don’t worry; we have got you covered. In this article, we will provide you with the ultimate guide on how to convert DAV to MP4 effortlessly. We will go through the different converters available with objective reviews.
Why Convert DAV to MP4?
DAV files are a proprietary video format used by some security camera systems to store surveillance footage. While DAV files are useful for their high-quality video and audio recordings, they can be challenging to work with because they require special software to play or edit.
- DAV is incompatible with many devices and players
- DAV files are known for their large size, which can quickly fill up your device's storage
- Most editors cannot open DAV videos, which makes it hard to custmoize
Top 6 Converters to Convert DAV to MP4 Free Online
If you want to play DAV files, we have mentioned below media players integrated with DAV file codecs and in-built tools to convert DAV to MP4 online and enjoy your DAV-captured content.
1. UniFab Video Converter
Install and launch the UniFab Video Converter on your device first.
Choose Converter Module, and then add the DAV file video into UniFab.
PROS | CONS |
2. Minitool Video Converter
MiniTool Video Converter is a tool that allows users to convert video and audio files between various formats. The tool offers a user-friendly interface with simple controls, making it easy to convert videos and audios without any technical expertise. MiniTool Video Converter also provides additional features like video editing, merging multiple files, and adjusting parameters such as resolution, bitrate, and frame rate.
PROS | CONS |
3. WinxDVD
The third on our list is WinxDVD, which can be your go-to choice if you're looking for a media player that also converts the DAV to MP4 free. The interface of WinxDVD is very minimalistic and easy to understand and provides high-quality conversion from one file format to the other.
PROS | CONS |
4. VideoSolo
If you want to use an advanced video converter to convert your DAV to MP4 and 200 plus more file formats, you can check out VideoSolo. It offer a range of software tools designed to help users edit, convert, enhance, and enjoy their multimedia files across various devices and platforms. VideoSolo is known for the user-friendly interfaces, powerful features, and broad compatibility,
PROS | CONS |
5. Online Video Convert
Next up on our list is Video-Online-Convert, a mult-ifeatured converter that you can install on both windows and mac devices. Even if you have the most basic knowledge of video editing and DAV to MP4 conversion, you can easily use it. In addition to conversion features, the site also offers online screenshot tools, as well as compressing document files, image files and video files.
PROS | CONS |
6. AnyMP4 Blu-ray Player
Last on our list is AnyMP4 Blue-ray Player that you can use for multiple format support. You can easily use it to convert DAV to MP4 format. Furthermore, it also designed to play Blu-ray discs, DVDs, and various video and audio formats on your computer. It offers high-quality playback and supports 4K UHD and 1080p HD videos.
PROS | CONS |
The benefit of converting .dav to mp4 is that you will be able to play them on any device as it is such a popular format, and you won’t even have to find a compatible media player. You can download the PlayerFab DVD player as it supports all file formats.
You can convert DAV to MP4 free using a compatible media player if your files are not playing on your computer or mobile devices. MP4 is a very popular file format easily supported by most DVD/ Blu-ray disc players.
If the DAV file doesn't open or work on your computer, that is basically because you don't have the compatible media player to play them. And in that situation, you will need to download a DVD media player that can either play the files or convert DAV to MP4 or other popular video formats like AVI. You can download the UniFab Video Converter as it supports all video file formats.
You can convert DAV to MP4 online using UniFab Video Converter or a compatible media player encrypted with DAV codecs. After downloading the media player, you will select the DAV files, upload them to the player, and convert DAV to MP4 or any other popular file format.
Final Words
DAV is an amazing format, but you need to convert it into common file formats to make it compatible to play. We want to conclude the article by reminding you to download the UniFab Video Converter to convert DAV to MP4 online for free. Depending on your requirements, you can choose the best video converter that we recommend for you.
