Top 10 Face Generators: Pros, Cons & Specifications
Summary: To create any random face of your choice & specifications, you need the advanced AI technology of the best face generator with a few clicks.
- • Enlarge photos up to 40x with more details added
- • Sharpen photos by reducing background/chroma/luminance blur
- • Make photos clearer by removing motion blur and out-of-focus blur
- • Suitable for both beginners and experts
While working on a digital platform, you need specific fake but natural-looking images to meet your various requirements of marketing, project presentation, advertisement, etc. While comprehending this requirement, the different AI face generators have come into play to get you realistic fake faces within seconds. So, here you will get the top 10 face generators to make your job easy and convenient.
Top 10 Face Generators to Make Fake Random Faces
While using the advanced technology of AI face generators, you can create fake faces according to your specific needs and preference. So, let's see which one will keep you ahead in advancement.
1. DVDFab Photo Enhancer AI
With the advanced deep convolutional neural networks technology of DVDFab Photo Enhancer AI, you can upscale any image with your specification. Whether it's a fake photo of any AI face generator or any old blurry black & white image, you enhance the resolution of any image without compromising its original quality.
Pros
- Enhance 2D/3D anime images up to 40x.
- Customize images while adding cartoon effects.
- Get color images out of the black & white ones with AI automatic technique.
- Excel the appearance of any random image to the perfection of a DSLR camera.
- Eliminate digital noise while reducing blur & enhancing the sharpness of any image.
Image Enhancing Steps
Step 1: Launch the software to download the AI model
Start launching the software on your PC, & select your required module. You should wait a while to download your selected AI model.
Step 2: Select an image to enhance
Opt for the "+" option, and drag & drop the image for enhancement in the software's main interface.
Step 3: Go for preview to change settings
While previewing the output result, you can make changes through the settings if it is needed.
Step 4: Save the final image
After your final customization, go for the "Start to Process" option to save the final images.
2. NightCafe
Being one of the fascinating AI face generators, NightCafe allows you to create any realistic or artistic random face of your preferences. Along with generating random faces, you can make images like a dog, fantasy landscape, etc., to use them on social media platforms, digital marketing, etc.
Pros
- You can describe your preference for faces like young women, CEO, etc.
- Face style selection option of black & white/ artistic color is available.
- It can create looks from text descriptions or existing images.
- NightCafe allows you to select purposes of "deep fakes" or "nefarious" uses.
Cons
- The free version/trial option is unavailable.
- It could be more evident in the creation process.
3. This Person Does Not Exist
This Person Does Not Exist is a renowned random face generator to get your desired faces in a single click within a few seconds. This technology focuses on different dimensions of fake faces, like teeth, hair color, background, accessories, etc., to make them real and reliable.
Pros
- The GAN technology of this tool consists of two neural networks.
- There is a refresh option to change the auto-generated face if you don't like it.
- The AI-generated faces are less than 90% recognizable by ordinary people or 50% by professional photographers.
- It offers NVIDIA "StyleGAN algorithm," which is glossy "water splotches."
Cons
- Everything in this tool is automatic; there is no customizable feature.
- Contains multiple ads.
4. Generated Photos
Generated Photos is a popular real-time app that allows you to create any face while setting your parameters. It gives you enough customizable options to add unique inputs to any machine-generated face.
Pros
- Multiple face parameter selection options of skin tone, sex, age, makeup, hair color, hair length, etc., are available.
- There are 11,232,000 variants to portray the same face with different dimensions & emotions.
- It has a three-day free trial.
- It provides realistic images & every image is different from the others.
Cons
- In the free trial, there is a watermark on the generated faces.
- Sometimes this tool crushes during the processing of images.
5. Prototypr
Prototypr is a professionally designed face generator with many customizable options and features. With this tool, you need to use your fingertips to create any faces of your images within a few seconds.
Pros
- Many options, like different emotions, skin colors, sex, etc. available to preset face-generating requirements.
- It supports model-released images to ensure your legal security.
- It gives photo-realistic faces through a simple interface.
Cons
- Comprises a few automatic default settings.
- Supports minimal features.
6. Datagen
Datagen is one of the smartest Al face generators to get realistic faces from unrealistic images. While providing control over intrinsic & extrinsic camera parameters, you can experience excellence in the execution of face generation of this tool.
Pros
- You can do anything with it, from a structural combination of hair, skin, age, etc., to lighting adjustments.
- Offers utterly controllable scene variations, including different domains of facial dimensions.
- Generates 100k+ faces through the high-res scan.
- 5000+ options of hair style & facial hair.
Cons
- There needs to be a business outlook.
- Little to experiment with this tool.
7. SnapCraft
SnapCraft is a very flexible random face generator to craft your face-generating creation with your customization. It doesn't require prior experience to create random faces.
Pros
- To identify age & gender, it uses the AI algorithm of pypy-agender.
- Straightforward & easy user interface.
- Every image is pre-analyzed through the AI technology of this tool.
- Consistently updated.
Cons
- There are no customizable features.
- This tool needs to be installed in your system.
8. Bored Humans
Bored Humans is a well-designed random face generator that gets you any fake & random face within a second. It allows you to explore unlimited, customizable features under one roof.
Pros
- It has a database of 70,000 real images to generate unlimited fake photos.
- It supports generative adversarial networks (GAN) to create fake faces.
- It offers 50 fun AI pages for free to explore your face-generating creativity.
- It supports old & new AI algorithms.
Cons
- The interface is a little complicated to use.
- It can be buggy sometimes while processing fake images.
9. Marketing Tool
A marketing tool random face generator is an effortless way to give a realistic appeal to any fake image. While using the reference of real photos, it eliminates the chances of artificial appearance to any fake faces.
Pros
- It uses facial impressions & features of real photos to generate fake faces to make them real.
- It provides the advanced technology of the Generative Adversarial Network (GAN) of Nvidia to reciprocate real vibration & emotion through fake images.
- You can get over 1 million auto-generated fake faces through this tool.
- It provides the fastest face-generating process.
Cons
- The output image-saving process is tricky.
- There is no manual selection option for facial variants.
10. FontSpace
With the smartest technology of the FontSpace face generator, you can make random Lenny faces with unlimited, customizable options. It is the best tool to showcase your creativity in expressing emotions through randomly created looks on social media, messaging or texting platforms.
Pros
- You can create random Lenny faces with 238,260 combinations.
- Best for emojis, emoticons, & kaomoji.
- You can select the size, shape & pattern of the nose, ear, eye, & mouth.
- These Lenny faces help to reciprocate instant emotions through the faces.
Cons
- Can't make fake faces of real humans.
- With this tool, you have to do everything manually.
What are the advantages of using Face Generators?
- It reflects artistic creativity of aesthetics and emotion while making any random fake face.
- It helps to demonstrate professional training where it is challenging to include real people.
- To experiment with a new look, style, or appearance.
- It helps to protect real identity.
- Using fake people's faces is more economical than real ones for business purposes.
What are the disadvantages of AI Face Generators?
- It breaks trust when using fake images.
- Fake faces are primarily used in scams.
- It generates counterfeit videos, photos & news for illegal activity.
- It helps increase corporate-level fraud & extortion.
What are the best fields to use a Random Face Generator?
- Education
- Training
- Game development
- Dating app
- Academic research
- E-commerce
Last Word
If you like to try out the modern techniques of AI face generators, you have found the best possible solutions through this article. So, while exploring the highlighted aspects of the top 10 face generators, you can pick the best-suited one. To stay one step ahead in perfection with your selected face-generating tool, you must try the photo enhancement technology of the DVDFab Photo Enhancer AI. In the meanwhile, DVDFab provides video converter tools, video upscaling tools, and other ai upscale video/editing solutions.
