Introduction
What is MOV?
QuickTime is often connected with the MOV video format. Apple is the creator of this video extension. It compresses video and audio using an algorithm.
What is MP4?
MP4, often known as MPEG4, is primarily a video format for storing video and audio information. It can also save images and captions. It is typically used to distribute videos over the internet. Any data can be included in MP4 over private streams. A unique suggestion is used in MP4 to include streaming data.
Most people nowadays consider MOV files to be obsolete and prefer to utilize MP4 files instead. Unfortunately, you may still have a large number of old MOV files clogging up your hard drive. With a bit of patience, you may convert them to an MP4 file type.
Best Methods to Convert MOV to MP4
Although MOV files are high-quality videos, not all media players can play them. MP4 files are universally accessible and take up less space on the hard drive. To give broader access and smaller file sizes, MOV files can be converted to MP4 in various ways.
Trying to understand how to convert MOV to MP4 quickly? This article will teach you how to convert MOV to MP4 quickly and for free. We'll look at how to:
How to Convert MOV to MP4 Online Using DVDFab
dvdfab video converter
DVDFab Converter is a fantastic programme that not only converts between different audio and video formats but also allows for simple editing and parameter modifications.
With the trimming tool, you can alter the length of your new clip after you've uploaded your MOV video. Slide the handlebars to establish the desired parameters for your new film and get right to the fun stuff.
Furthermore, the DVDFab toolkit is a must-have multimedia editing toolbox with many features. It's made up of audio and video editing widgets, each serving a specific purpose. Crop, trim, rotate, or flip videos, for example. Mix audio files and control the volume. Convert images to GIF or video formats, and add watermarks or subtitles. Video and audio should be extracted. And there's a lot more!
Step 1: Download and install the software.
DVDFab Video Converter is a programme that is included in the DVDFab Suite. Assuming you've downloaded DVDFab Suite, open it and select the Converter tab from the menu bar at the top.
Step 2: Drag your video files onto the page.
You have several choices for importing your files into the software. Through the Add from local option, you can use the regular browse and add a feature. You may even load the MOV files from a DVD.
Step 3: Customize the settings as per your requirements.
Just beside the file you've just added, click the wrench symbol. You'll be able to access the Advanced Settings option after that. You can use the pen symbol to open a video editor and make tiny changes. You can change the codecs, resolution, video quality, and bit rate, among other things, during the conversion process.
Step 4: Prepare your files for conversion.
That's all there is to it. Now that you've set your preferences for the output video, all you have to do is select your output folder and click Start. The conversion process will now begin. A progress indicator can be used to track the conversion process progress.
Convert on Mac Using iMovie
mov to mp4 converter
You can use iMovie to convert your MOV to MP4 on a Mac. You might not be able to find a way to convert if you explore throughout the app because, like QuickTime, iMovie only has the export option:
However, it turns out that when you use iMovie's Export File feature to export your MOV, the final file is an MP4.
All you have to do to convert your MOV to MP4 with iMovie is follow these steps:
  • Import your video through iMovie
  • Then at the top right, click the Share icon
  • Select your desired video settings and the location for the exported file before starting the conversion.
Note that your converted MP4 will most likely not be put in the same folder as your original, so make sure you're happy with where your converted file will be saved before you start the conversion.
Convert Via CloudConvert
CloudConvert is simple to use, fast and works on both Macs and PCs with an internet connection. You must upload your video files to a remote server, with the understanding that the company that converts your video may have access to them. And, while using online conversion tools, we believe it's important to remember to use caution when converting potentially improper or private videos. CloudConvert, on the other hand, appears to be a great online file conversion solution with no severe concerns that we are aware of.
The MOV to MP4 converter from CloudConvert makes it simple to convert MOV files to MP4 online.
How to use CloudConvert to convert your MOV video files to MP4
1. Launch CloudConvert's MOV to MP4 converter, choose your MOV video, and click "Select File."
2. Now select "Convert" to begin the MOV to MP4 conversion.
3. When you're finished, click the green "Download" button to save your video in MP4 format.
Convert Via Wondershare Video Converter
Wondershare Free Video Converter is a free desktop application that works on Windows and Mac computers.
One disadvantage of the free version is that the converted video will have a watermark.
1. Download and run the app on your Mac or Windows computer. To import your MOV video from your PC, click the Add Files option.
2. After the MOV video has been imported, the destination format will automatically be set to MP4; click the "Convert" button
Convert Via VLC
If you already have VLC installed on your computer, you can utilize it as a MOV to mp4 converter.
vlc mov to mp4 converter
VLC instructions for converting MOV to MP4
1. On your Mac, install and run VLC, then go to the File menu and choose Converter / Stream from the drop-down menu. If you're using VLC on Windows, go to the Media menu and choose Convert / Save from the drop-down menu that appears.
2. Now, to import the MOV video file, click the Open media icon.
3. By default, the target format in the Choose Profile box should be Video – H.264 + MP3 (MP4).
4. Finally, select the Save as File option to give the converted MP4 file a name and save location, then hit Save to begin the conversion.
This article is solely to assist users with the conversion of MOV to MP4 video. Because video file conversion necessitates the use of a trustworthy free video converter, you have the option of using VLC or searching the internet for free video converters. However, utilizing a powerful third-party programme like DVDFab Video Converter is the best option.
Is there a simple way to convert a MOV file to a MP4 file?
Multiple online and offline MOV to MP4 converters are available on the market to make convertingMOV files toMP4 files easier. You can pick from a variety of tools depending on your needs. For example, the best MOV to MP4 Converter for Windows and Mac 90x faster without quality loss is DVDFab, an easy-to-use online free MOV to MP4 Converter.
Which is better, MOV or MP4?
There is no correct response to that. MOV files are not supported by many players or post-production programmes, so they must be converted to a new format to be compatible. Due to the high compression, editing MP4 files can be difficult.
Will there be a loss of quality while converting MOV to MP4?
When you convert MOV to MP4, all you're doing is wrapping the streams within the MOV file in an MP4 wrapper. As a result, there will be no compromise in terms of quality.
