How to Convert M4a to MP3 in 2024
Summary: With the massive success of the iPhone, there was a rise in the need to convert M4A to MP3 since MP3 is one of the most widely supported audio formats on Apple devices. However, converting a file from M4A to MP3 can be a headache if you don’t know the right processes and have the right tools. And that is why, here, we have discussed some of the most popular video converters that you can easily avail and have talked about their features. To help you convert videos like a pro, we also have detailed guides on how you can use those video converters properly.
Record designs were extremely important just a decade or two ago when you think about it. Individuals were debating the merits of various record compressions, and it was occasionally necessary to develop an application enhancement in order for it to run a specific document design.
Everything appeared to change with the iPhone's widespread success. Since all records were now facilitated inside programs, we never had any issues with contradictions. Similarly, when more of our work transfers to the web, it is quickly stored inappropriate programming, eliminating the need to manage document designs。
In all likelihood, you will encounter a record that you are unable to open or the necessity to convert a sound document to a different format. Managing M4A files, which you usually want to convert to MP3s, is probably one of the most well-known problems for Mac users. As a result, we can see what the M4A format is and where you can find the finest M4A to MP3 converter on the market today.
What Is M4A and How to Use It
Assuming that you consider M4A records like MP4s, which they basically are, you'll be more OK with them. The main distinction is that an MP4 document can deal with video, though an M4A record can't. The m4a design is just for sound.
MP4 (otherwise called MPEG-4) depends on the QuickTime File Format (QTFF) and was intended to supplant MP3 here and there. M4A documents, for instance, are less in size and can store better music than MP3 records. The main hindrance is that M4A players are more challenging to drop by, while MP3 is one of the most generally utilized sound arrangements.
Given the current state of affairs, where would you look for the.m4a record design? It's the default document expansion for music downloads in Apple's iTunes Store, and it's then, at that point, compacted with AAC for more modest records or ALAC for lossless sound. Then again, Copyrighted tunes might be in the.m4p design, which is a variant of.m4a.
All of this makes one wonder how to play M4A documents on a Mac and what is the least complicated method for changing records over to MP3.
How to convert M4A to MP3 in iTunes
While Mac has various M4A players, both implicit and outsider, you might observe that you really want to change M4A over to MP3 iTunes configuration to make it all the more broadly accessible - permitting you to quickly move music or book recordings to almost any gadget.
Surprisingly, there is a way to utilize iTunes to convert audio files; however, few people are aware of it because it is not simple. In any case, here's how to use iTunes to convert a file to MP3:
- Open iTunes (or the new Music app)
- Open Preferences (⌘ +,)
- Go to Files > Import Settings.
- Change the Import Method to MP3 Encoder and click OK.
- Into iTunes, drag and drop your M4A file.
- Select it, then choose File Convert Create MP3 Version from the drop-down menu.
- Locate the newly produced file in your library (the old file will still be intact)
You may alter the default iTunes encoder to create WAV, lossless, AIFF, and AAC files in the same way. iTunes is a decent M4A converter and general record converter to MP3 if you only need to change a few tunes every now and then. For more continuous changes, there are a number of more capable programs available.
So if you are wondering how do I convert M4A to MP3 without iTunes, then this might be the best available option you can find on the internet. You can convert M4A to MP3 on Windows, convert M4A to MP3 on Mac, as well as convert M4A to MP3 online.
Best Way to Convert M4a to MP3
DVDFab Video Converter - Mac M4A to MP3 converter
DVDFab Video Converter is the most satisfactory choice for changing M4A over to MP3 on Mac, and it is genuinely, additionally viable with the Windows working framework. Contingent upon your necessities, you can utilize it to change sound over to sound, video to video, and video to sound. Presently, if it's not too much trouble, stay with me while I tell you the best way to utilize this Mac M4A to MP3 converter.
Features
DVDFab Video Converter can read all of the necessary audio and video codecs from video cameras, memory cards, and other sources and convert them to over 1000 different video and audio formats.
You have complete control over the audio output when you convert M4A to MP3 on Mac. You can convert only a portion of the audio if you wish, and you can also choose the output audio and subtitle stream. As a result, you will not only receive a high-quality conversion but also a plethora of customizing options.
The following are the steps to convert M4A files to MP3 using DVDFab Video Converter:
- Download DVDFab Video Converter from the official site and install it.
- On the top, select the Converter module.
The audio can then be dragged and dropped onto the DVDFab window. You may also manually add audio from the file explorer by clicking the Add button (+).
- This M4A to MP3 converter accepts M4A files.
- Here comes the most interesting part – Customization.
- Select "Choose Other Profile" from the drop-down menu and MP3 as the Audio Format.
Do you want to tweak the sounds a little more? When you go to the Advanced Settings area, you can change a variety of audio parameters.
- Set the destination for the output (Mobile Device, Folder, YouTube, Vimeo, Facebook)
- Begin converting M4A to MP3
It will begin converting the video immediately and provide you with real-time updates. You can also pause the procedure whenever you wish. If the conversion is taking too long, choose the option to turn off the computer once it is finished.
And that's how you convert M4A to MP3 on your Mac.
Despite the fact that there is a paid version, you may learn how to convert M4A to MP3 on Mac for free. For a limited number of conversions, there is a trial version that provides you access to all of the premium features.
DVDFab video converter is a fun and simple-to-use audio converter with features that no other converter can match. Furthermore, the DVDFab Video Converter produces higher-quality audio output than any other audio converter we tested. This is our preferred Mac M4A to MP3 converter.
Toolkit - Windows M4A to MP3 converter
Toolbox is a very helpful and free program that can perform a wide range of tasks, including converting M4A files to MP3.
Features
It can be used to switch between video and sound, trim video and sound, adjust video playback speed, pivot video, crop video, deshake video, and denoise sound, merge recordings or sounds, extract video or sound from a document, generate or concentrate captions, and so on.
To use it to convert M4A to MP3, simply follow the directions below.
Steps on how to change M4A to MP3 with Toolkit:
- Download and install DVDFab Video Converter Pro for Windows for free. Open the M4A to MP3 audio converter.
- Choose a Toolkit module.
- Under Audio Tools, select the Converter option.
- Fill in the blanks with your M4A file in this free M4A to MP3 converter.
- Choose MP3 as the output audio format.
- Set the audio codec, data rate, channels, and sample rate as needed (optional)
- Choose a location to save your converted M4A to an MP3 file.
- Start by pressing the Start button.
This is how to use the Toolkit module in DVDFab Video Converter Pro to convert an M4A to MP3. You could wonder if this audio converter accepts M4A as a source file. The answer is a resounding YES. M4A, M4B, WMA, WAV, MP3, APE, FLAC, AAC, AC3, AIF, AIFF, AU, RAM, OGG, MKA, MP2, and RA files may all be read by this free M4A to MP3 converter. Toolkit can support a total of 17 different file formats.
CloudConvert - Online M4A to MP3 converter
You'll need to install third-party software on your computer to convert M4A to MP3 on Windows or M4A to MP3 on Mac because I understand that section. There are many free M4A to MP3 converters available online, including you may not want this, I've included an online M4A to MP3 converter in this cloud converter, ZamZar, Convertio, Online Audio Converter, Online-Convert, and others. The majority of M4A to MP3 converters work in the same way. As an example, I'll use CloudConvert to teach you how to convert an M4A to MP3.
How to use CloudConvert to convert M4A to MP3 online:
- Go to CloudConvert's official website.
- Select an M4A file from your PC, Google Drive, Dropbox, OneDrive, or by URL by clicking Select File.
- Wait for this M4A to MP3 converter to finish processing your file (Minutes Long)
- Set the "Convert to" option to MP3 format.
- To convert M4A to MP3, click the Convert button.
Consider using a web-based sound converter to convert M4A to MP3. It's simple to use, but maintaining a database for online programming might take up a lot of time. As a result, you should exercise restraint. If you have a large number of M4A files to convert to MP3 formats, DVDFab Video and Toolkit converter, both of which provide cluster conversion from M4A to MP3, are worth looking into.
How To Convert M4A to MP3 Using Windows Media Player
Windows Media Player is a default media player for Windows which can play many media files such as WMV, WMA and MKV and MP3. A need may arise, you may want to convert M4A to MP3 format, and the only converter you have at your disposal is Windows Media Player. Follow the steps below for how to convert M4A to MP3 using Windows Media Player:
- In Windows Media Player, open your M4A file(s).
- Go to the menu and select the Organize option.
- From the drop-down menu, choose Options.
- Select RIP Music from the drop-down menu.
- To choose a destination for the converted file, scroll down and click Change.
- In the Format section, choose MP3 from the drop-down selection.
- Select OK.
Wrapping Up
Some M4A to MP3 converters are regularly suggested on the rundown when you look for how to change M4A over to MP3 on Google, Safari, or different sites. Each of them gives off an impression of being valuable; however, they aren't.
Use DVDFab Video Converter Pro, Toolkit, or online sound converters to change M4A over to MP3 with or without iTunes, depending upon your necessities. I'd like to believe you had a wonderful time converting M4A to MP3 for free and quickly.
