[Review] TOP 10 Best AMV Converter Software to Use in 2025
Summary: The demand for AMV converter tools has increased recently seeing the rising fan following of Anime. Anime normally comes in AMV format and hence the need for an AMV video converter is felt. But what is this AMV format? And which is the best and free AMV converter tool. Read below to get answers to all your questions.
What is an AVM File?
The AMV file extension refers to the Anime Music Video files. They are normally used by portable media playing devices belonging to China. These video files are enhanced for the media players. It is assumed widely that MTV was the brain behind the development of the file format. AMV files are compressed files of a normally very low resolution.
These videos can have a resolution in the range of 94x64 to 160x120, which ideally fits the screens of the target devices. These devices often come with extra software that lets AMV files be played and opened on a computer too. AMV files have been developed based on the AVI container.
Now that you are aware of what AVM file format is, let us have a look at some of the best and most free AMV video converter tools.
Best 6 AMV Converters [Tested and Verified]
UniFab Video Converter
Install and launch the UniFab Video Converter on your device first.
Select the video/file you want to convert from AMV to MP4 and add it into UniFab Video Converter.
Customize the format and video resolution you want, then, click the Start button to convert your AMV file to MP4 format.
RCA AMV Converter
RCA AMV Converter is a free AMV converter for mp3 players and was created to assists users save their favorite media files in effortlessly accessible forms. For example, the tool can be used for saving AMV clips in AVI and FLV or extracting MP3 audio.
As it suffices the latest needs of the users, the process of conversion is effortless. After burning a video, the tool looks at the data to make sure that no data was lost. The UI is easy to use, so you will find all the features that you may require.
VSDC Free Video Converter
Similar to other YouTube to AMV converter tools, VSDC boasts an impressive set of features, which makes this free converter a must for anybody who wishes to find a simple-to-use solution. It can convert your media files in no time and offers powerful performance.
The tool also supports popular codecs, such as H.264/AVC, DivX, AAC, and MP3. Whether you require to play your files on iPod, Xbox, PSP, or iPhone, you can re-size and save AMV videos without any trouble. Before you begin converting your file, ensure to configure its settings. You can set a frame rate, choose a codec, and set aspect ratio as well as resolution.
VLC Media Player
VLC Media Player is believed to be one of the best and most free MP4 to AMV converter tools for Windows, Mac, iOS, Linux, and Android. While most people use it to play MOV, MKV, MP4, AVI, RAW, and FLV files, this converter supports other media formats too. After choosing a file on your device, you can tweak output settings as per your needs.
Tanbee Video to AMV Converter
Tanbee is an easy-to-use AMV converter that allows you to save files in your preferred formats. It boasts a streamlined interface, offers fast performance, and comes with enhanced editing options, which makes it an ideal option for many users.
The major benefit of this AMV converter is its quick speed. It allows you to convert your videos in no time to be compatible on your device in a format as per your preference. The interface is simple to handle, so you will not face any problems when working with your files.
Leapic Media Converter
If you are searching for a reliable and quick AMV video converter, you can consider this option. Apart from converting videos into different formats, for example, MP4 into AMV, it can also can convert APE files into MP3. After installing this tool, you can work with files in popular formats, such as WMV, VOB, AVI, FLV, OGG, M4A, AAC, MOV, MKV, WMA, F4V, 3GP, MP3, APE, MP4, etc.
This tool allows you to crop, rotate, and flip your videos. To enhance the process of conversion and make your task simpler, there are 100 pre-configured settings. With them, you can save files that can be compatible with PS3, PSP, iPhone, iPad, BlackBerry Xbox, Android, and other devices.
Movavi Video Converter
Movavi is one such converter that has gained recognition among video enthusiasts. You can use it to convert AMV files to other formats like MP4, AVI, MOV, and more. The AMV converter also allows you to customize your videos by adjusting parameters like resolution, bitrate, and frame rate.
Wondershare UniConverter
Wondershare UniConverter is an excellent choice for anyone looking for a versatile and reliable AMV converter. Its powerful features, fast conversion speeds, and user-friendly interface make it a top contender among the best AMV converters available in the market.
One of the most impressive features of Wondershare UniConverter is its speed. It uses advanced technology to convert videos in a matter of seconds, without compromising on quality. Additionally, it allows you to customize your videos by cropping, trimming, merging, and adding watermarks or subtitles.
Freemake Video Converter
One of the best features of Freemake AMV Converter is its ability to handle batch conversions, which allows you to convert multiple files at once. This feature is especially useful if you have a large number of AMV files that need to be converted. Additionally, the program lets you customize your output files by adjusting the resolution, bitrate, and frame rate to suit your needs.
Online Convert
Online convert tool is a powerful AMV converter that offers an easy-to-use online tool to convert your videos quickly and efficiently. With its intuitive interface, anyone can convert their video files into AMV format in just a few clicks.
If you don't want to download any app on your device, an online converter suits you best.
AMV means Anime Music Video. From the term itself, it aims at animation. This format is usually developed by clipped images from animation with the help of background music and transition tools. MAD is more aimed at the world of video games. On the other hand, MAD does not essentially aim at anime.
Having said that, we just had a look at the best AMV video converter tools. Among those, UniFab Video Converter is the best option that can be used for conversion. The tool can convert video from one format to another, including your favorite AMV format. Also, the tool can convert video to popular audio formats. Furthermore, these audio files are playable on different devices, as well.
