DVDFab Blu-ray Ripper
Rip any Blu-ray to any video & audio formats in 15 minutes
Get gapless playback on any device, media player, or home theatre
Windows
Mac
Try for Free
100% Safe & Clean
Last Update: Apr 2, 2025
Best Blu-ray Ripper to Remove Any Old or New Protection
DVDFab Blu-ray Ripper can automatically remove any common Blu-ray copy protections: AACS, BD+, BD-J, RC, Country Code, etc. So you are able to rip any encrypted Blu-rays.
And the Cloud Decryption Service exclusive to DVDFab can also remove protection from newly purchased encrypted Blu-ray discs in the cloud server timely and quickly. That's why you can open any old or new disc in 5 to 10 seconds.
blu-ray ripper
Rip Blu-ray to 1000+ Video/Audio and Devices in 1:1 Quality
  • Lossless Conversion
  • High-Quality Compression
  • Multi-Format Output
Rip Blu-rays to Video & Audio of Lossless Quality for Home theatre
DVDFab Blu-ray Ripper can rip any Blu-ray to lossless video (MP4/MKV/M2TS.Passthrough) and audio (DTS-HD, TrueHD, TrueHD Atmos, DTS:X), leading to quality playback for home theatre.
When running this best Blu-ray Ripper, you will be asked to set a preference for playback mode, be it Mobile, theatre, AI, or Web. Whichever you choose, it will ensure you the highest viewing experience.
blu-ray ripper
Compress Video Size but Retain Quality for Any Mobile Device
This best Blu-ray ripping software can also convert Blu-ray movies to mainstream video formats playable on all mobile and portable devices, without any loss of the original quality.
For instance, MP4 is the most compatible video format with a smaller file size but better quality, which can be played on all devices. Try to watch Full HD movies on your smartphones or tablets whenever you want.
rip blu-ray for backup
Rip Blu-ray/ISO/Folder to 1000+ Video & Audio Formats
DVDFab Blu-ray Ripper is designed to convert any Blu-ray disc, ISO image file or Folder to 1000+ video (MP4, MKV, AVI, MOV, WMV, FLV, M4V, TS, DivX, WebM, 3GP, etc.) and audio (MP3, WMA, AAC, M4A, FLAC, OGG, etc.) formats for playback on various devices.
For device compatibility, this top Blu-ray Ripper can rip Blu-rays to more than 245 preset devices such as Apple, Google, Huawei, Microsoft, Samsung, and Sony.
To customize the output videos, you can utilize Profile Filter (3D, Passthrough, 4K/5K/8K, H265, 10/12 bit etc.) and Advanced Settings (Codec, Frame/Sample Rate, Resolution, Quality, Channels, Subtitles, etc.).
Rip Blu-ray at 50x Faster Speed
Get 50x Faster Blu-ray Ripping Speed with GPU Acceleration
DVDFab Blu-ray Ripper boasts the latest advanced GPU acceleration technologies including Multi-core CPU, NVIDIA CUDA, AMD, IQS (Intel Quick Sync), Video ToolBox (macOS), which enable you to rip a standard Blu-ray movie in 15 minutes.
Convert Blu-rays to Digital Files via Multitasking Mode
Task Queue is a major bright spot in DVDFab products. Once you add multiple Blu-ray ripping tasks to the queue of this top Blu-ray ripper, all the tasks will be finalized one after another, which saves you time for other matters.
Make Your Video Outstanding with Built-in Video Editor
  • Crop
    Crop
    Crop video to desired aspect ratio
  • Trim
    Trim
    Trim unwanted clips to make a video perfect
  • Watermark
    Watermark
    Add a watermark (image/text) to the video
  • External Subtitles
    External Subtitles
    Add external subtitles (SRT/ASS format) to the video
  • Merge
    Merge
    Merge multiple clips into a single one
  • Brightness
    Brightness
    Adjust brightness, contrast, and saturation
DVDFab Blu-ray Ripper can easily rip Blu-rays to 1000+ video and audio formats while also enabling you to edit your Blu-ray video with its in-built professional editor. You can crop, trim, merge video, add watermarks and subtitles, and even adjust video color, making your videos stick out from the crowd.
More Functions in the Smart Blu-ray Ripper Software
  • AI-Enhanced Video Quality
  • Remove Cinavia Watermark
  • Generate Friendly Metadata
  • Convert Subtitles to SRT File
Upscale Video from SDR to HDR10 with NVIDIA AI Enhancer
DVDFab Blu-ray Ripper works seamlessly with NVIDIA AI Enhancer to convert video from SDR to HDR10 on Windows PC, improving contrast and color range while enhancing detail in shadows and highlights.
With HDR becoming the standard for video content, converting Blu-ray video from 1080P SDR to 4K HDR will ensure that the video remains visually appealing as the technology advances.
Upscale Video from 1080p to 4K with AI Enhancement
Remove Blu-ray Cinavia and Create Clean Audio
This best Blu-ray Ripper, working with DVDFab Blu-ray Cinavia Removal, can remove Cinavia protection completely and permanently.
By creating a non-Cinavia backup with lossless AAC/AC3 audio (up to 2.0 or 5.1 channel), DVDFab lets you enjoy clean audio from your Blu-ray on all the affected playback devices.
Friendly Meta Info and .nfo File Perfect for Media Server
DVDFab Blu-ray Ripper boasts an exclusive Meta Info feature that aims to automatically synchronize the meta info of the source BD such as movie title, cast, and cover.
Moreover, this top Blu-ray ripper can generate .nfo file by default so that all the meta info will be clearly displayed on the media server, like PlayerFab, Plex, and Kodi. You can gain a full picture of the attached details associated with the BD source.
Convert Blu-ray Subtitles to SRT File via OCR Tech
DVDFab Blu-ray Ripper gives you full freedom to customize the subtitles as your personal preference. You can set subtitles in various ways, including directly rendering to video, remuxing into file, or extracting to IDX/Sub file.
Besides, based on OCR (Optical Character Recognition) technology, this Blu-ray ripping software can also convert Blu-ray subtitles to SRT format (Windows Only) for seamless playback on TVs or mobile devices.
Functional Comparison of DVDFab Products
DVDFab Blu-ray Copy
$69.99
Buy Now
$69.99
Buy Now
Supported Discs
Newest Commercial, Rental Blu-ray discNewest Commercial, Rental Blu-ray disc
Output Format
BD/ISO Image File/FolderOver 1000 video and audio formats including MP4, MKV, MP3, etc.
Support Adult Blu-rays
Remove Newest Blu-ray Protections
Lossless Backup to BD50
Compress to BD25/BD9/BD5
Supported Copy Modes
Full Disc
Main Movie
Customize
Clone/Burn
Merge
Burn ISO image file to Blu-ray
Output Video Resolution
LosslessLossless
Upscale to 1080P/4K
Hardware GPU Acceleration
How to Rip Blu-ray Free with DVDFab Blu-ray Ripper
  • Launch DVDFab and load Blu-ray disc/ISO/folder
    Run DVDFab 13 and opt for the Ripper module. Insert BD into the external Blu-ray drive, navigate it through the Add button, or drag and drop an ISO file or folder onto the main UI.
    Choose one profile and customize the output video.
    Start to rip a Blu-ray
80+ Million People Like Our Blu-ray Ripping Software
System Requirements
  • Windows 11/10/8.1/8/7 (32-bit/64-bit)
  • Pentium II 500 MHz
  • 2GB of RAM
  • 100GB of free hard disk space
  • A Blu-ray drive
  • Live Internet connection required
Input
Blu-ray disc (2D & 3D), Blu-ray folder, Blu-ray ISO image file
Output
3D Videos: 3D MKV.H.265, 3D MP4.H.265 3D MP4.4K, 3D MKV.4K, 3D AVI, 3D MP4, 3D WMV, 3D MKV, 3D M2TS, 3DTS
2D Videos: H.265, MP4.4K, MKV.4K, MPEG-4, MP4 Passthrough, MKV Passthrough, MP4, FLV, MKV, AVI, WMV, M2TS, TS, etc.
Audio: MP3, MP4, M4A, WMA/WMA10, WAV, AAC, DTS, OGG, PCM and AC-3/E-AC-3 5.1 etc., with up to 7.1 channels
Frequently Asked Questions
  • Is it legal to rip Blu-ray?
    It is generally legal to rip Blu-rays for personal use, as long as the Blu-ray disc belongs to you or is not distributed or used commercially. However, it is always important to respect copyright laws and use DVDFab Blu-ray Ripper responsibly.
  • Does ripping a Blu-ray damage it?
  • What is the best file format for ripping Blu-rays?
  • How long does it take to rip a Blu-ray?
  • Is there a free Blu-ray ripper of DVDFab?
  • Does DVDFab Blu-ray Ripper leave a watermark?
  • Blu-ray copy vs. Blu-ray ripper software, what is the difference?
Can’t find the answers you’re looking for? If you have other problems, don't hesitate to contact us.
Our Service Team is always ready to help. Your problem will be addressed as soon as we can.
Tips & Tricks for Easy Blu-ray Ripping
  • Top 5 Free Blu-ray Decrypters for Legal Use [2025]
    WennyApr 1, 2025
    Blu-ray Discs are a superior way to enjoy high-definition movies at home. However, its embedded encryption technology makes it challenging to access the content. This guide features 5 of the best free Blu-ray decrypters to help you easily unlock Blu-ray protection. Read on to find your solutions!
  • How to Convert Blu-ray to MP4 on Windows & Mac: Top 6 Converters
    WennyMar 20, 2025
    If you want to enjoy Blu-ray movies on devices like iPads, TVs and tablets, converting them to MP4 is an optimal way. This process not only preserves the quality of your movies, but also improves their accessibility. In this article, we will guide you through the steps of converting Blu-ray to MP4 with ease using the best software for Windows and Mac.
  • How to Rip Blu-ray Discs : Top 8 Tools for Beginners and Pros
    WennyMar 21, 2025
    In this article, we will guide you through how to rip Blu-ray using the best free Blu-ray ripper available in the market. Not only will this help preserve your beloved Blu-ray movies and shows, but it also offers increased accessibility and convenience in viewing them.
Fair Use Policy : DVDFab is intended for personal use only, and sharing copied content with any third party is strictly prohibited.
To ensure a stable user experience and prevent potential restrictions from disc publishers, each DVDFab licensed account has a quota of 100 disc copies per week. This quota will automatically reset at the start of a new weekly cycle.
