How to convert WAV to MP3 offline and online [Windows/macOS/Online]
Summary: How to convert WAV to MP3 easily and quickly? Reading this article, you will find more than one answer to this question, and you’ll be able to find the WAV to MP3 conversion solution that fits your circumstance the best.
WAV and MP3 are the two of the most popular audio formats seen in our everyday life, so why do we need to convert .WAV to .MP3? As we all know, the WAV format is an uncompressed lossless audio format usually used in CD recording, mastering, and advanced audio applications. The word uncompressed means that WAV files are usually large in size. To help you understand better, a CD recorded at 44.1 kHz and 16-bit is about 30MB on average, and standard WAV can even take up to 500MB.
As a result, WAV music files are impractical for portable devices and distribution over internet, especially in this streaming era. Think iTunes, Spotify and the likes, why are those streaming services are offering MP3 music instead of WAV? The reason cannot be more obvious! File size is the pain. MP3 is a compressed lossy audio file that takes much less free space but still offers quite stunning sound effect, especially at higher 320 ~ 512 kbps. Plus the fact that the difference between a WAV file and an MP3 file on a portable device is not that big to average listeners with poor headphones or earbuds, then it is quite reasonable to convert WAV to MP3 so that even hundreds of songs won’t take too much storage of your smartphone.
Having understood why there is the need to convert .WAV to .MP3, then let’s move on to the subject of how to convert WAV to MP3, either with a mp3 to wav converter software or a free WAV to MP3 converter online service.
Part 1. Convert .WAV to .MP3 with the best offline WAV to MP3 Converters
How to convert WAV to MP3 either on Windows 10 (and earlier versions) and macOS Big Sur 10.15 (and earlier versions)? The 1st most advanced WAV to MP3 converter software coming into my mind the Video Converter Pro suite from DVDFab Software, that contains world’s three best video & audio conversion and editing tools, namely the Video Converter from DVDFab 12, the 28-set DVDFab Toolkit, and the DVDFab Video Editor.
You may wonder, how do you convert .WAV to .MP3 format with those video converter and editing tools? Well, don’t judge a software’s capability just by its name. Except for the DVDFab Toolkit, the other two software products may take video inside their names, the fact is that both three products feature the expertise to convert WAV to MP3 format and thus can be used solely as WAV to MP3 converter tools.
Besides, all the three products offer 30-day free trial period for you to evaluate their features and functions. This means, you can use either of them as a free WAV to MP3 converter for as long as 30 days. So you have plenty of time to test the reliability of them before making your decision to upgrade to the premium versions.
1.1 How to Convert WAV to MP3 with DVDFab Video Converter (Windows & macOS)
Like mentioned earlier, as a professional video converter software, DVDFab Video Converter not only tops in the video conversion realm, but also excels in the audio conversion field. As for how to convert WAV to MP3 fast and efficiently, this WAV to MP3 converter won’t disappoint you either. It is capable of converting audio files between literally any two known formats, and WAV to MP3 is certainly covered, too.
Key Features of this WAV to MP3 Converter:
- Convert WAV to MP3 files at 320 kbps that’s almost near Hi-Fi quality
- Allows for customization of output audio parameters of your preference
- Support to batch convert .WAV to .MP3 to save you much valuable time
- Support GPU hardware acceleration to further speed up the conversion
- Convert audio files between any two commonly seen popular formats
Without further ado, now let’s check out how this WAV to MP3 converter can help you convert .WAV to .MP3 files easily on either Windows or macOS of all versions.
Step 1 — Download and Installation of this WAV to MP3 Converter
Before you can convert .WAV to .MP3 on your computer with this top-notch WAV to MP3 converter software, the very 1st thing to do is of course to download and install it on your PC. To do that, just click the two Download buttons below, one for Windows, the other macOS.
Step 2 — Launch this WAV to MP3 Converter to Load the WAV Files
Once the installation is completed on your computer, double-click its desktop icon to launch the program, navigate to the Converter module, and load your WAV file(s) using the giant Plus button centered in the main interface, the Add from Local button at the upper left corner, or simply drag & drop the WAV file(s) here.
Additional Tips:
See that Add from Mobile button next to the Add from Local button? One of the amazing bonus features of this WAV to MP3 converter is that it allows you to directly add your WAV files from a mobile device, whether a smartphone or tablet, either iOS or Android, as long as you install DVDFab Remote to that device to serve as the virtual data cable via Wi-Fi, which also means you don’t need to bother your physical data cable any more.
Step 3 — Choose the MP3 Profile for the WAV to MP3 Conversion
Now that you’ve added the WAV file in, it’s time to choose the correct conversion profile from the built-in Profile Library, in our case, the MP3 format. To do this, click the “Choose Other Profile” option from the dropdown menu of Profile Selection Box. This will take you to the built-in Profile Library, where, as its names indicates, hundreds of pre-configured and tested conversion profiles designed for different video containers and all the playback devices you can think of are listed. You just need to move to the Format > Audio section, and then select the MP3 format for this WAV to MP3 conversion task.
Step 4 — Customize the WAV to MP3 Parameter Settings as Wish
For most of the common users, having chosen the correct conversion profile is just one step away from initiating the WAV to MP3 conversion process. However, if you are a techy guy or someone who is little bit adventurous and wants to experiment with different audio settings, then you are welcome to click the Wrench icon that opens the Advanced Settings panel where you can reset the audio channels among the available options including Mono, Stereo, Dolby Surround/ProLogic and Dolby ProLogic II, adjust the volume and the bitrate as well.
About the bitrate: Given the fact that the process from WAV to MP3 is a procedure involving compression, so how to convert WAV to MP3 without compromising too much on the audio quality? When the audio codec is set in the stone, then the trick goes to the bitrate, you can tweak the bitrate to a higher level, such as 320 kbps, a near Hi-Fi quality that can almost rival the lossless WAV format in terms of sound quality.
Step 5 — Start the WAV to MP3 Conversion Procedure
When all are ready, then you are okay to click the Start button at the bottom right corner of the main interface to start to convert WAV to MP3. It will just take a blink to process the conversion for one WAV file, even without turning on the GPU hardware acceleration feature.
Additional Tips: Another bonus feature of this WAV to MP3 converter is its support for batch conversion. Suppose you have a pyramid of WAV files, then you may care about how to convert WAV to MP3 in batch mode. Actually it’s super easy too. Just drag & drop all the WAV files into this WAV to MP3 converter, and then when you select the MP3 format from the built-in profile file library, don’t forget to tick the option of “Use for all sources”, which will do the trick of applying the MP3 output format to all the loaded WAV files at one go, saving you much time tweaking one by one.
Alright! All the detailed instructions above show clearly demonstrates how to convert WAV to MP3 with DVDFab Video Converter with ease. Hope you enjoy the process. Now, let’s move on to another WAV to MP3 converter which is much simpler, the DVDFab Toolkit.
1.2 How to Convert WAV to MP3 with DVDFab Toolkit (Windows)
As an audio/video/image multimedia conversion and editing suite, DVDFab Toolkit so far has packed 28 handy video, audio and image conversion and editing tools that are frequently used in our everyday life. Each module is an independent product that works on its own and does only one primary job. The Converter module from the Audio Tools section, for example, is the WAV to MP3 converter we’re looking for today to convert WAV to MP3 file.
- Convert WAV to MP3 at up to 512 kbps lossless
- Allows to customize output audio parameters
- Support to batch convert WAV to MP3
- Convert audio files among popular formats
Now let’s see how the Audio Converter module serves as the WAV to MP3 converter that help us convert WAV to MP3 with no sweat.
Step 1 — Download and install DVDFab Toolkit, using the download button below. As of now, only the Windows version is available.
Step 2 — Navigate to the Audio Tools section after launch of the program, and then click on the Converter module.
Step 3 — When at the Converter module, click the giant plus button to load your WAV files, or simply drag & drop them here.
Step 4 — After loading the source WAV files, choose the MP3 format from the output dropdown menu, your favorite audio channel and preferred bitrate of up to 512 kbps. To be noted that, although bitrate is an important fact affecting the sound quality, if you are only going to play those converted MP3 files on you smartphone or tablet, the there’s no big deal between 320 kbps and 512 kbps, as you probably won’t hear any difference on your earbuds.
Additional Tips: This WAV to MP3 converter also supports batch conversion mode, however, unlike the video converter above, you’ll have to select the MP3 output format manually for each WAV file.
Step 5 — If you’re done with the settings, then click the Start button to trigger the WAV to MP3 conversion. The entire conversion only takes a few seconds for each WAV file.
Okay, here we are! When conversion finishes, transfer the output MP3 file(s) to your smartphone and start enjoying your Sunday afternoon in your comfortable sofa.
1.3 How to Convert WAV to MP3 with DVDFab Video Editor (Windows)
So far we’ve learned how to convert WAV to MP3 with the Video Converter and Toolkit from the Video Converter Pro suite, the only left one is the Video Editor. Despite not a dedicated WAV to MP3 converter, it does feature that function, and also offers the same advanced options compared with the former two WAV to MP3 converters.
- Convert WAV to MP3 or AAC at up to 320 kbps
Now let’s walk through the steps to see how Video Editor can convert WAV to MP3 in the simplest way:
Step 1 — Download and install Video Editor to your computer via the Download button below, which is only for Windows platform as of now.
Step 2 — Launch the program, use the Import button at the upper left corner to load the WAV file (or, you can also use the drag & drop way) to the Media Library, and then click the green plus button that appears when you point your curser to the WAV file to add it to the timeline of the working area below.
Step 3 — Click the Export button from the top left menu bar, then at the popup window, move to the Audio tab to select MP3 from the video format dropdown menu. The last thing to do is to click the Export button to convert WAV to MP3 file.
Additional Tips: the Gear icon behind the format selection box will take you the audio settings window where you can customize according to your own needs on WAV to MP3 conversion.
Part 2. Convert .WAV to .MP3 with a free WAV to MP3 Converter Online
Apart from using desktop WAV to MP3 converters to convert .WAV to .MP3, there are also many free WAV to MP3 converters that you can use directly from a web browser. This means you don’t have to install anything except that you will need to upload your WAV files to the website to perform the conversion online.
Next, let’s take a closer look at one of the best free WAV to MP3 converter online services that you can benefit from. Convertio.co website offers many online services, converting WAV to MP3 is just one of them. With just a few steps, you can complete the WAV to MP3 conversion process.
Refer to the illustrations below to see how to convert WAV to MP3 with this simple online service:
Step 1 — Load the target WAV file using the Choose Files button, or you can also directly add files from Dropbox, Google Drive or a URL as well;
Step 2 — When the WAV file finishes loading, click the Gear button behind the MP3 format selection box to change relevant settings as you wish, including channel, bitrate, frequency and volume. This free WAV to MP3 converter service even allows to trim your WAV length to save only the portion you want. What a sweet feature it is!
Step 3 — Click the giant red Convert button to trigger the WAV to MP3 conversion procedures.
Additional Tips: To be noted, before the conversion begins, it will 1st need to upload the WAV file to their server which might take a few minutes depending your network speed and the size of your WAV file. And when the conversion finishes, you will have to download the final MP3 file back from their server which shall cost you some period of time again, if you have many WAV files to convert.
Final Words
The properties of the WAV audio format determines that it is not suitable for distributing music over internet, especially in today’s environment where streaming is taking over. Consequently, MP3 format becomes the universal choice for streaming services. What’s more, as far as individuals are concerned, converting WAV to MP3 makes it possible for us to take thousands of songs and music files on a smartphone without eating up the storage.
In this article, we’ve discussed the reason why we sometimes need to convert WAV to MP3 format, how we can convert WAV to MP3 with offline WAV to MP3 converter software on PC or free WAV to MP3 converter solution directly from a web browser. Similar to WAV vs MP3, there is no absolute winner between an offline WAV to MP3 converter software and an online WAV to MP3 converter service. Each has its pros and cons.
Most of the WAV to MP3 converter software may be not free, but they are professional, fast and efficient when converting WAV to MP3, such as the Video Converter, Toolkit and Video Editor that are covered by the Video Converter Pro suite we recommended in this article. While online WAV to MP3 converter services are free, they are inefficient in conversion itself, you even might have to queue up for one conversion job. That’s to say, the final decision is still in your own hands. Choose what fits you best! And one more last thing, if you’re also interested in how to convert videos to MP3 file, don’t hesitate to check out this article.
