3 Best Online Free MP3 Cropper
Summary: If you want to make a ringtone from your favorite song, you can use the MP3 cropper to split it or trim the unwanted parts. If you are looking for the best MP3 Cropper, you are now finding the right way! This passage will introduce the 3 best MP3 Croppers online and free to solve your problems.
- • Offer diversified aspect ratio for display
- • Accept file or folder import like video, audio and image
- • Enable you to add text, filters, transitions, overlays and elements, mosaic
- • Allow you to rotate, split, crop, zoom in/out and edit your files in other ways
- • Output files in various formats of high quality
Best MP3 Cropper: DVDFab Video Editor
Video Editor is an unprecedented video editor you have never seen. You could also crop MP3 using it directly. It is simple enough for even beginners and powerful enough for almost the most demanding filmmakers. Video Editor places a strong emphasis on the creative process, allowing you to bring your imagination to life, giving you a space to experiment with ideas and enjoy trying different things.
Unique Pros
- Extensively supported formats
No matter you need wav, mp3, m4a, mid, flac, aac, wma, au, aiff, ogg or other formats, Video Editor could cover all these formats.
- Audio Detach
With just one click, you can separate audio from video for further detailed editing. When complete, the audio clip will be detached from the video and immediately displayed in the audio timeline. But still, keep the original video clip.
- Multiple choice
Video Editor provides a powerful audio library for adding music and sound effects to videos for specific purposes. Click on the "Audio" tab in the sidebar and select "Music" from the given templates.
- Record, edit and master your audio
Adjust volume to 400%, fade or mute in just a few clicks. Double-clicking an audio clip in the timeline brings up a window where you can adjust the playback speed of the audio clip and drag the sliders to set the fade in and fade out effects as desired.
- Insert your own pre-recorded narration or voiceover.
The microphone icon on the toolbar represents voiceover recording. Video Editor will record your voice and play it automatically in the preview screen. Double-click a recording on the voice-over timeline to adjust the audio speed, volume, or add a fade effect.
- Access to royalty-free music and sound effects
Video Editor is filled with a selection of royalty-free music and sound effects. You can choose from built-in music for emotional, moving background effects, or choose from specific sound effects to add interesting details to your projects.
Once you’ve added the audio file to the timeline, you're ready to start to crop MP3! Different audio clips can also be dragged to different tracks. You can choose from a variety of editing tools, choose from numerous preset audio and element effects to make your audios unique! The preview is always displayed in the upper right corner, so you can always be sure of the result.
How to Use DVDFab Video Editor to Crop MP3 File?
- Add Background Music to Video
Click on the “Audio" tab in the sidebar and select "Music" from the given templates. Note that all these music files and sound effects are stored in the cloud. Therefore, you need to download (↓) the music or sound effect you want first, then click the plus (+) icon to load the selected file into the audio timeline.
- Create Audio Sequence
Select Add to Project to import the selected audio into the audio timeline, select an audio clip, hold down the mouse, and move the file forward or backward to adjust its order as desired.
- Split Audio Clips
Select the loaded audio file in the timeline and move the slider to the position you want to cut. Click the Split (scissors) button on the toolbar, or right-click the audio clip and select Split from the context menu to split the audio clip into multiple parts.
- Crop Audio Clips
Move your mouse over the edge of the audio clip displayed in the timeline until the double arrow icon appears. Hold down the left mouse button and move the mouse left or right to retain the desired portion of the entire audio file.
- Adjust Volume
Double-click an audio clip in the timeline, or right-click an audio clip and select Edit, where you can turn the volume up or down. Just drag the slider from left to right and vice versa to increase or decrease the volume.
- Fade in & Fade out
When the audio editing window appears, drag the sliders to set the fade in and fade out effects as desired.
All in all, you can edit your audio with Video Editor with a simple click, so that your audio file better suits your needs.
123APPS
As is known to all, 123APPS is one of the most popular online MP3 audio cutters. It is an online application that allows you to cut audio tracks directly in your browser. The app is fast, stable, supports over 300 file formats, fades and ringtone quality presets, and is completely free.
A Detailed Guide on How to Crop MP3 Files
- Open mp3cut.net in your browser.
- Open the file you want to crop.
- Choose the interval you want to cut by moving the blue slider.
- Adjust the audio track fade in from silent and gradually increase in volume
- Choose a format you wish to save a file in.
- Click “Cut” button.
- Download.
Pros
- Support all kinds of formats
You could feel free to use this online MP3 Cropper to cut any format of audio. However, if your file fails to open, then it is probably damaged or it is too big.
- Security guaranteed
There is no need to worry about the security problems when using 123APPS because your files will be automatically deleted from the servers a few hours after you are done working with them. Nobody is able to gain access to them except you.
Cons
- Limited file size
Users are only allowed to trim files up to 4GB, which will pose a great challenge to some audios.
Clideo
Clideo has gained a lot of popularity due to its powerful functions as well as considerate designs and is considered as one of the most professional and convenient online MP3 Croppers.
Features
- Fast cutting
Users won’t have to wait for a long time for the results, only a few seconds could accomplish all the steps.
- User-friendly Tool
The interface of the audio trimmer is very intuitive, so you won't have any problems editing your music
- Completely online
There is no need to download and install the MP3 song cropper, which makes the whole process faster.
- More Settings
With this tool, you can also fade in and out your music tracks and convert them to any format you may need.
Pros
- Support any video format
The video trimmer works with all the popular formats such as AVI, MP4, VOB, MPG, MOV and others. Armed with Clideo, the compatibility of different formats and devices will not be a problem any longer.
- High Level of Security
no one except could gain access to your uploaded files for this powerful online MP4 Cutter uses premium online security.
Cons
- Limited file size
Clideo only enables users to cut a video file up to 500MB for free.
How to Use Clideo to Crop MP3 Online?
- Add an audio
Choose a file from any device: PC, Mac, Android or iPhone. Files can also be dragged and dropped onto website pages or selected from Dropbox or Google Drive.
- Crop uploaded song
Select a part of the audio. MP3 Music Cropper lets you extract or delete it. After that, check the Fade in and Fade out, or Crossfade boxes. Then change the audio format—MP3 is great for ringtones.
- Download the file
When you're done processing your file, save it to your laptop, phone, or return to cloud storage. Read the full guide to the tool to learn more.
This user-friendly MP3 Cropper is appropriate for novices, if you are not familiar with these kinds of tools, you could still crop and edit your audios with ease.
How can I split MP3 files into parts online?
Double click on the link "FILE" for an in stored MP3 audio file or "URL" for an online audio file and then on what subtends click on "choose file" then upload the intended file from your computer or the URL for the online audio file. Step 3. Select the part you want to cut by entering the start and endpoint.
How do I compress files without losing quality?
Open your file in Audacity. Go to File > Export and select the format you want to save the file in. Under Format Options, choose the Bitrate Mode (variable or constant), then set a Quality. Hit Save to save a newly compressed file.
Can I trim audio with VLC?
Using VLC. VLC comes with a range of inbuilt options, such as converting file formats and even trimming mp3 files).
This article provides a handful of powerful and convenient MP3 croppers, both PC and online software. If you would like to crop and edit your MP3 files in a short time, these products can definitely meet your needs.
