How to Extract Audio from MP4? Solved!
Summary: We are going to discuss some of the best softwares, and methods that you can use to help you extract audio from any MP4 video. So, if you have a video that has good background music, and you want to extract it for your personal use, then you should read this article till the end. So without any further ados, let us jump straight into the article, and discuss how to extract audio from any MP4 video files.
- • Offer diversified aspect ratio for display
- • Accept file or folder import like video, audio and image
- • Enable you to add text, filters, transitions, overlays and elements, mosaic
- • Allow you to rotate, split, crop, zoom in/out and edit your files in other ways
- • Output files in various formats of high quality
How to Extract Audio from MP4 Video and Files?
Extracting an audio task from any MP4 file might sound to be a difficult task that is best left to professionals. Although this statement used to be true a few years ago, it is fortunately not the case anymore. With the advancements made by humans in the field of science and technology, there are loads of softwares today that help you extract audio from any video file with just the click of a few buttons.
However, today, there are hundreds of offline, and online softwares present on the internet that claim to help you with extracting audio from video files. But it is worth noting that all of these softwares do not work the way they advertise. Most of the time, these softwares are nothing but hoaxes, and some of them even contain malicious files that can cause a lot of damage to your computer when installed on your device.
So it is suggested that you should only download those audio extraction softwares that have a good reputation amongst the existing users, and you should download them only from genuine, and trustworthy sources.
However, if you are not a professional, or if you do not have a lot of experience with these video & audio editing softwares, you might be confused when it comes to choosing the best software that suits your needs the best. Out of all the softwares on the internet, the “DVDFab Video Editor” video editing software is one of the best softwares that would help you extract audio from any video file with ease.
Use DVDFab Video Editor to Extract Audio from MP4
The DVDFab Video Editor video editing software is one of the most popular, and most used softwares in the world for video and audio editing purposes. The DVDFab Video Editor software is an extremely powerful, and capable software that allows you to edit your videos as per your requirements without any troubles, and with just a few clicks.
The DVDFab Video Editor is an all-in-one software that not only allows you to edit your favorite videos, but also allows you to edit audio files, and images as per your needs & requirements. You can use the DVDFab Video Editor to convert, trim, or edit your MP4 files. You can change the format of these MP4 files, and we have already covered an article on how to change the video format using the DVDFab Video Editor.
How to Use the DVDFab Video Editor to Extract MP4 Files from Videos?
Now that we have discussed what is the DVDFab Video Editor video editing software, let’s have a look at the detailed guide on how to use this software to extract MP4 files from your favorite video files.
Step #1: Download the software
Before you can start using the DVDFab Video Converter, you will have to download it first. Although the DVDFab Video Converter software is available on a lot of websites, the easiest and safest way to download the file would be via the official website of DVDFab. The home page of the website would look like this.
Locate the DVDFab Video Converter option, and click on it. A new webpage would load, and you will see a “Download” button on the top. Click on the button, and a setup file would start downloading. Or you can save yourself the trouble, and directly visit the official website using this link.
Step #2: Install the software
Once the setup has been downloaded, you need to install the software on your device. Double click on the setup file, and follow the instructions that pop up on the screen.
Step #3: Add the video
Once the software has been downloaded and installed on your device, it is important to add the video from which you want to extract the audio. To add the video, click on the “Add from Local” or “Add from Mobile” options present on the top-right bar of the window. Else, you can also click on the “Giant +” icon present on the center of the window.
Step #4: Select the Video Format
Once you have added the video file, it is important to select the video file format if you want to. Spot the “Choose Other Profile” option from the “Profile Selection Box”, and click the following options in the same sequence: Format - > Video - > General, and select the video format as per your requirements.
For example, if you want to extract audio from an MP4 video file format, select the “MP4” option.
Step #5: Trim the Video
Once you have selected the video file that you want to extract the audio from, and you have defined its format, it is important to trim the video. In this step, we would be selecting the initial and final positions from which you want to extract the audio.
Click on the “Video Editor” icon, and click on the “Trim” icon. Now, you will see the timestamp, and two playheads, one for the initial position, and one for the final position. Adjust them as per your requirements.
Once the playheads are in their respective positions, click on the “Trim button” present on the bottom-left corner of the window. Finally, click on the “OK” button to finalize the positions, and trim the video for the selected duration.
Step #6: Select the Audio Format
Once you have finalized the timestamps, it is important to select the audio format. Go back to the “Profile Library” and click on Format > Audio. Once clicked, you will get a list of audio formats supported by the DVDFab Video Converter. Select the audio file format as per your requirement.
Step #7: Customize your Audio
Now that you selected the timestamps and audio formats, it is time to customize the audio as per your requirements. You can change the name of the file, and if there are multiple audio files by any chance, you can select any one of them.
If you are a professional, and you want additional toys to play with, you can click on the “Advanced Parameters option”, and this would display a whole other list of advanced features that would help you customize the audio files for your professional requirements.
Step #8: Start the Conversion Process
Once you have done all the previous steps, it is time for you to start the conversion process. Click on the “Folder” option to select the output location for the converted file. Once done, click on the “Start” option to start the conversion process.
DVDFab Video Editor: Additional Features
Allowing you to extract audio from MP4 files is just one of the many features offered by the DVDFab Video Editor video and audio editing applications. You can use this software to help you with the following tasks as well.
Feature #1: Edit Audios Easily
We have already seen how the DVDFab Video Converter helps you extract audio from Mp4 files. But it also helps you in editing these audio files as per your requirements. You can trim them, add various effects, and more with ease.
Feature #2: Add Background Music to a Video
We have just seen how to use the DVDFab Video Converter to extract audio from a video. But the DVDFab Video Converter allows you to add background music to a video as well. Not only can you add any audio file of your choice to your video’s background, but you can also select any audio file from DVDFab Video Converter’s in-built audio library.
Feature #3: Record Voice Overs
Voiceovers are one of the primary requirements for a lot of video creators, especially those who upload their videos on YouTube or other social media platforms. Voice over means adding your recorded voice to a video, and the DVDFab Video Converter is one of the best softwares for this role.
Final Thoughts
In this article, we have told you everything you need to know about how to extract audio from MP4 files, and how to extract audio from MP4 online. We have also discussed why the DVDFab Video Converter is one of the best softwares that would help you extract audio from MP4 files as per your needs and requirements.
The DVDFab Video Converter is a pretty simple application thanks to its user interface. In case you are not sure how to use the software to extract audio from your MP4 files, we have added a detailed guide with a step-by-step process that would help you with extracting audio from your favorite MP4 files.
