MOV to MP3 | Convert MOV to MP3 Free & Easily
Summary: If you are a QuickTime Player user, you might need to convert MOV to MP3 for offline play on multiple mobile devices especially when you are driving or traveling on the train. This post focuses on the top 3 solutions for how to convert .mov to mp3 in easy clicks with different mov to mp3 converters. Read on for more details.
Are you looking for a quality mov to mp3 converter that enables you to convert mov to mp3 for offline listening on various mobile devices? There might be times when you are tired of playing MOV files via QuickTime on iOS and macOS devices. Under the circumstances, a mov to mp3 converter will come in handy. However, searching for a reliable one counts much. This post offers a top list of .mov to mp3 converters for your option, thus saving you much time and energy.
PART 1: Why Convert MOV to MP3
As we know, MOV is a file format developed by Apple Inc used to store digital media including videos, movies, and audio, which is designed for QuickTime Player. It is compatible with Windows and macOS. In most cases, it is primarily used for editing and less for actual use. However, a MOV file format is not compatible with actual devices.
On the contrary, the MP3 file format is noted for its smaller size and full compatibility. That being said, you can playback MP3 files on almost all devices. But one of the biggest disadvantages lies in that MP3 adopts a lossless algorithm to reduces file size by deleting lesser audile music content. That means the final output music quality will be undermined. However, that does not affect its popularity for wide playback on various devices.
Therefore, in terms of compatibility, you are advised to convert MOV to MP3 for flexible playback whenever and wherever possible. To achieve this aim, you need to make the right choice from numerous options to be discussed in the next part.
PART 2: Top 3 MOV to MP3 Converters Worth Your Try
Among all known video to audio converters, there is one video converter, DVDFab Video Converter Pro, which stands out from the rest thanks to its versatile and powerful features.
- Available on: Windows
- Pricing: Free trial, $59.99
- Highlighted features:
- Convert all sorts of videos and audios into other popular formats supported by multiple devices
- Edit videos or audios via multipurpose edits and creative effects
- Customize quality output via parameter settings
- GPU acceleration to quicken the conversion process
- Work with Enlarger AI to upscale low-res videos to 4K
- Intuitive interface, perfect for personal and professional use
Note that DVDFab Video Converter Pro consists of three modules, namely, Video Converter, Video Editor, and Toolkit. Video Converter, available on Windows and macOS, can be used to convert video or audio between all popular formats, including mov to mp3 conversion. Meanwhile, Video Editor, compatible with Windows, can convert .mov to mp3 while editing videos, audios, or images. Now let’s take a look at them respectively.
How to Convert MOV to MP3 with Video Converter
- STEP1: Launch DVDFab Video Converter Pro and choose the Video Converter module
- STEP 2: Load MOV video file and choose MP3 profile
- STEP 3: Start to convert MOV to MP3
After converting mov to mp3, the final output mp3 audio file will be saved on your hard drive by default. Of course, you can click the Earth icon and share the mp3 file on your social networks such as YouTube and Facebook.
Warm tips: if you want to convert mov to mp4, you can tab the Enlarger AI icon that enables you to ai upscale video from 480p to 1080p.
How to Convert MOV to MP4 with Video Editor
- STEP 1: Launch DVDFab Video Converter Pro and choose the Video Editor module
- STEP 2: Import MOV video file to the timeline and edit video as desired
- STEP 3: Click the Export to convert .mov to .mp3
Video Editor is far from converting mov to mp3. It has many other features that deserve your full attention. Take a quick look at the below features.
- Basic editing: trim, crop, split, rotate, reverse, video speed, background color, audio volume, color correction, mosaic, zooms, freeze frame, set duration, text and speech converter, record (PC, phone, or camera screen)
- Special effects: text, audio, overlays & filters, transitions, elements
- Export: quality video (MP4, MKV, AVI, WMV, MOV, GIF), audio (MP3, AAC)
- Import media from PC hard drive, camcorders, DV cameras, vidicons, webcams, smartphones (with various formats of MP4, AVI, WAV, 3GP, FLAC, MP3, JPG)
As to how to use Video Editor, hover your mouse click on this link for more detailed information.
Aside from converting mov to mp3 with Video Converter and Video Editor, DVDFab Video Converter Pro also offers a free cloud service that allows you to convert MOV to MP3 online. After finish the mov to mp3 conversion, you can normalize audio with Toolkit to improve your audio quality.
Convertio.co
Apart from the mov to mp3 online converter of DVDFab Video Converter Pro, there are other options for you to reach the same goal. For example, Convertio.co is a handy online video converter able to convert videos and audio between popular formats, including .mov to mp3. Then how to convert MOV to MP3 easily?
- STEP 1: Upload MOV files from the computer, Google Drive, Dropbox
- STEP 2: Choose mp3 as output format
- STEP 3: Download your mp3 video file for other use
iTunes
It is an indisputable fact that iTunes, developed by Apple, is a media player, media library, Internet radio broadcaster, mobile device management utility, and client app for the iTunes Store. It can be applied to play, download, purchase, and organize digital media files on personal computers running Windows and macOS, and can be used to rip songs from CDs. To some extent, it can be used as a mov to mp3 converter.
How to Convert MOV to MP3 in iTunes
- STEP 1: Download and Open iTunes on Windows or macOS
- STEP 2: Go to Preference > General > Import Settings > MP3 Encoder
- STEP 3: Load .mov file and select Convert from the File Menu option
In this way, you will get the .mov to .mp3 file converted via iTunes.
Final Thought
In this post, you must have got the hang of how to convert mov to mp3 free and easily with different mov to mp3 converters. As a saying goes you can't have your cake and eat it too. But you can achieve this goal if you choose the right tools. With DVDFab Video Converter Pro, you can convert mov to mp3 and edit the audio as well. Once installed, you can choose different modules to meet your personal needs.
By the way, if you want Netflix download for offline play, go to DVDFab home page and choose Netflix Downloader to download Netflix movies. Meanwhile, you can download streaming video from other streaming sites including Disney+, Amazon Prime Video, Hulu, HBO, and more.
