Introduction to Converting BDMV to MKV/MK4
Despite the excellent quality they offer, BDMV files come with a range of complications, primarily concerning compatibility. However, there's a solution—perhaps a shift to a more universal format like MKV or MP4 could offer a more seamless and enjoyable viewing experience.
This article will explore the reasons why we need to convert BDMV to MKV or MP4, and then introduce the 5 best BDMV converters that offer efficient and reliable solutions for converting your BDMV files.
convert bdmv to mkv
What is BDMV and MKV?
BDMV stands for Blu-ray Disc Movie Video, which is essentially a digital format used for storing HD video content found in Blu-ray discs. It allows storing of high-definition videos up to 1920x1080 pixels with surround audio and has the ability to support menus like DVDs. However, this format is not as widely supported on media players as some others.
On the other hand, MKV is an open-source multimedia container format, which can hold an unlimited number of video, audio, picture, and subtitle tracks in one file. It has become a popular choice due to its versatility and maximum quality preservation, which has earned it wide compatibility with various platforms and devices.
Why Convert BDMV to MKV/MP4?
Converting BDMV to MP4/MKV generally gives you more flexibility and portability with your media:
Compatibility: the compatibility of MP4 and MKV files is superior to BDMV, making them playable on almost all devices, including smartphones, tablets, computers, and smart TVs.
Compression: BDMV files tend to be larger. Converting BDMV to MKV/MP4 can reduce the file size significantly without compromising the quality of the video or audio. It is also more convenient to manage, share and store smaller file sizes especially if storage space is limited.
Top 5 Best Tools for Converting BDMV to MKV/MP4
avatar
Before diving into the detailed introduction of the best BDMV to MKV converters, we've compiled a comprehensive comparison table based on our test team's extensive trials. By reviewing this side-by-side comparison, you'll get a preliminary understanding of how each product performs, helping you make a more informed choice.
  Cross-platform Support Output_Formats 3D Support Batch Conversion Subtitle Support
DVDFab Blu-ray Ripper Windows, macOS MKV, MP4, AVI, 1000+ formats Yes Yes Yes (internal/external)
MakeMKV Windows, macOS, Linux MKV only Yes No Yes
(forced subtitles)
HandBrake Windows, macOS, Linux MP4, MKV and WebM No Yes Yes
(external only)
AnyMP4 Blu-ray Ripper Windows, macOS 500+ formats Yes Yes Yes
Leawo Blu-ray Ripper Windows, macOS 180+ formats Yes Yes Yes
DVDFab Blu-ray Ripper [Best BDMV to MP4 Converter]
DVDFab Blu-Ray Ripper is a professional and reliable Blu-ray video converter that supports converting BDMV files to MKV or MP4 formats efficiently. It can also convert any 2D/3D Blu-ray discs, ISO files, or folders to over 1000 video (2D/3D) and audio formats, even if your Blu-ray has any old or new copy protection. Moreover, you can customize the video and audio parameters like title, chapter, audio tracks, subtitles, codec, quality and size.
 Key Features of DVDFab Blu-ray Ripper
  • Remove the latest protection(AACS/BD+/BD-J/RC) to make BDMV conversion possibl
  • Rip a standard Blu-ray movie in 15 minutes with GPU Acceleration
  • Support multitasking mode for batch Blu-ray ripping
  • Convert BDMV folder (.m2ts file) to 1000+ video/audio formats, such as MKV and MP4
  • Rip BDMV files to lossless video (MP4/MKV/M2TS.Passthrough) and audio for home theater
  • Compress BDMV file size but retain quality for playback on all portable devices
  • Offer a built-in video editor to crop, merge, add watermarks or effects to your BDMV videos
💻Supported OS:
tips icon
DVDFab Blu-ray Ripper also offers a lifetime-free but simplified version - DVDFab HD Decrypter - that can rip most encrypted DVD and Blu-rays to MP4&MKV format only. Both versions are installed in one DVDFab package for your easy use.
MakeMKV [Free BDMV to MKV Converter]
MakeMKV is an open-source software used for ripping DVDs and Blu-rays to the MKV format only. It can be also used to convert Blu-ray Disc Movie (BDMV) files into MKV with all audio tracks and subtitles retained. This BDMV converter can only process AACS or BD+ protected files, so it doesn't work on converting BDMV files with DRM or other kinds of protections.
💻Supported OS: Windows, Mac and Linux
 Pros
  • MakeMKV offers a straightforward and user-friendly interface.
  • This BDMV converter offers a free beta version to try its full functionality.
  • It preserves the original video and audio quality during the conversion process.
  • MakeMKV utilizes efficient algorithms to convert BDMV files quickly, saving you time.
  • It allows you to select and include all or specific subtitles, audio tracks, and chapters from the original BDMV file.
❌Cons
  • Limited output formats: It converts BDMV files to MKV format only.
  • MakeMKV does not provide advanced video editing features.
  • The output MKV files are large, which may consume more storage space.
Convert BDMV to MKV via MakeMKV
HandBrake [Free BDMV to MP4 Converter]
Handbrake is an open-source and multithreaded video transcoder that can convert BDMV files to MP4, MKV and WebM formats that are more readily usable across a wide range of devices. It also supports convert both DVD or Blu-ray files without copy protection mechanism. Additionally, Handbrake also provides options to crop and adjust your video during the BDMV files conversion process.
 Pros
  • Handbrake is a totally free BDMV to MKV/MP4 converter.
  • It provides extensive customized options, such as bitrate, audio tracks, subtitles, etc.
  • It offers pre-defined presets optimized for different devices and platforms.
  • You can queue multiple BDMV files for conversion and process them in batches.
❌Cons
  • Complex interfaces may not be user-friendly for beginners.
  • This BDMV file converter can only convert BDMV files to MP4, MKV or WebM.
  • HandBrake is unable to decrypt Blu-ray, so it cannot convert encrypted BDMV files.
Convert BDMV to MKV/MP4 with HandBrake.
AnyMP4 Blu-ray Ripper [Windows BDMV to MP4 Converter]
AnyMP4 Blu-ray Ripper is a powerful tool that can rip and convert all-region Blu-ray disc/ISO/folder to 500+ video and audio formats, including Blu-ray to MP4, MKV, MP3. etc. This BDMV to MKV/MP4 converter also allows you to edit and customize the output video by adjusting video resolution, bitrate, and other settings.
💻Supported OS: Windows 11/10/8/7
 Pros
  • Support for converting 2D Blu-ray movies to 3D MP4, 3D MKV, etc
  • Its GPU-accelerated technology enables fast Blu-ray ripping.
  • Supports viewing video effects and making adjustments before ripping.
  • Convert BDMV to MKV/MP4 and 500+ video/audio formats for playback on multiple devices.
  • It comes with a built-in video editor that allows users to crop, cut, and add subtitles to your BDMV files.
❌Cons
  • It is available for Windows, which limits its accessibility for Mac and Linux users.
  • If your BDMV file contains DRM protection, this ripper may not be able to bypass it.
Convert BDMV to MKV via AnyMP4 Blu-ray Ripper
Leawo Blu-ray Ripper [BDMV to MKV/MP4 Converter]
Leawo Blu-ray Ripper is a comprehensive Blu-ray/DVD ripping software that allows you to rip and convert Blu-ray, including BDMV files, to video in various formats, such as AVI, MP4, WMV, MKV, FLV, MOV, etc. Additionally, it can extract audio from Blu-ray movies and convert them into popular audio formats. This BDMV to MKV/MP4 converter also features video editing options, such as trimming, cropping, watermarking, and 3D settings.
💻Supported OS: Windows 7/8/8.1/10/11 and macOS 10.13...13/14
 Pros
  • It supports converting BDMV files to 180+ output formats, ensuring compatibility with a wide range of devices and media players.
  • This BDMV converter utilizes advanced algorithms to ensure high-quality conversion.
  • Convert various type of discs without the influence of disc protection and region restriction.
  • Offer advanced features like video editing, parameter adjusting and 3D video output.
❌Cons
  • It can't read and rip some newest copy-protected BDMV files.
  • It can't convert BDMV subtitle to SRT files.
  • The output of the free version is watermarked and the conversion length is limited.
Convert BDMV to MKV via Leawo Blu-ray Ripper
How to convert BDMV to MKV/MP4 with best Blu-ray Ripper?
Now that we've explored the top five BDMV to MKV converters, let's take a closer look at how to use DVDFab Blu-ray Ripper, one of the most reliable and feature-rich tools available. We'll walk you through the process, ensuring that you can easily convert your Blu-ray content with minimal effort.
Step 1: Launch this BDMV to MP4 converter and load Blu-ray disc/ISO/folder
Run DVDFab 13 and opt for the 'Ripper' module when it runs. Insert BD into the external Blu-ray drive, and navigate it through the Add button or drag & drop ISO file/folder onto the main UI.
Convert BDMV to MKV/MP4 with DVDFab Blu-ray Ripper
Step 2: Choose one profile and customize the output video
Click the 'Choose Other Profile' to select your desired profile as MKV or MP4. Select the titles, audio tracks, and subtitles you want to retain, or add external subtitles. Then turn to the 'Advanced Settings' and built-in 'Video Editor' to customize the output video.
Step 3: Start to convert BDMV to MP4 or MKV
Click the 'Start' button. You can cancel the task anytime you like, set PC to auto shut down, exit program, hibernate or do nothing when ripping Blu-ray is done.
Can VLC open and play BDMV files?
Yes. VLC is capable of playing BDMV files, especially unprotected ones, but lacks full Blu-ray functionality such as menu navigation and playback of encrypted commercial discs without additional decryption libraries.
Several disc authoring software with Blu-ray playback and burning capabilities can open BDMV files. Notable options include the free VLC media player, as well as professional programs like PlayerFab Ultra HD Player, JRiver Media Center, Nero, and Macgo Mac Blu-ray Player.
What is the Resolution of a BDMV File?
The resolution of a BDMV (Blu-ray Disc Movie) file can vary as it depends on the specifics of the disc. However, the common resolution for Blu-ray Discs is either Full HD, 1920 x 1080 pixels (standard high-definition) or 4K Ultra HD, 3840 x 2160 pixels (for newer and advanced discs).
Final Word
In conclusion, choosing the right tool for converting BDMV to MKV or MP4 depends on your specific requirements. The 5 tools we've covered in this article are the best options available in the market. Nevertheless, if we evaluate in terms of user-friendliness, flexibility, and comprehensive functionality, we strongly champion DVDFab Blu-ray Ripper as the premier software for your BDMV to MKV/MP4 conversion needs.
