Mac users have lately been searching for a powerful and reliable solution to rip Blu-ray on Mac and enhance their entertainment spree offline. The fact is that playing Blu-ray movies on Mac, iPhone, iPad and any device that supports video playback is no longer a tough task.
There are numerous free Blu-ray ripper for Mac available to assist you in this task. This article reviews the 6 best Blu-ray ripper for macOS, including free options, to assist you in choosing the best program for your needs.
Best and free blu-ray ripper mac: DVDFab Blu-ray Ripper
6 Best Blu-ray Rippers for Mac Worth Trying
We understand that setting for the right program can be tricky when you have many options to solve the purpose. Here, we will give a detailed review of the best software to rip Blu-ray Mac with their features, pros, and cons to help you pick one depending on your requirements.
1. DVDFab Blu-ray Ripper for Mac
DVDFab Blu-ray Ripper for Mac is an excellent software that rips Blu-rays to over 1000 video and audio formats at a blazing speed to get lossless playback on 245+ devices, including media players and even home theatre. This Blu-ray ripping software Mac can remove any Blu-ray protection and delivers high-quality compression with lossless conversion in multiple output formats. The built-in video editor is an added boon as it allows you to add external subtitles and watermarks and adjust brightness to make your video output personalized.
💻Supported OS:
Key Features:
  • Best Blu-ray decrypter that supports newly-released protected Blu-rays.
  • Rip Blu-ray disc, ISO file or Folder on Mac to over 1000 digital formats.
  • This free Blu-ray Ripper supports playing movies on 245+ devices.
  • Support batch conversion at 50 times faster Blu-ray ripping speed.
  • Choose Blu-ray titles, chapters, audio, and subtitles you want to convert.
  • Users can trim, crop and merge video, set brightness, and add watermark via built-in video editor.
WHAT WE LIKE
  • Handle any Blu-ray encryption.
  • Rip 2D/3D Blu-ray to 2D/3D format.
  • Built-in video editor.
  • GPU hardware acceleration.
  • Synchronize original meta data info.
  • Supports lossless compression and conversion.
WHAT WE DON'T LIKE
  • Users can only free experience DVD ripping on Mac.
  • Can't work on Linux.
2. Handbrake
Handbrake is one of the most powerful and open-source Blu-ray ripper for Mac, as it has built-in device presets to help you select a universal profile for standard and top-notch conversions. The program can process common multimedia files and even rip some protected DVDs and Blu-ray discs without hassle when used with a libdvdcss decoder.
💻Supported OS: Windows 10 and later, ARM devices, Mac 10.13 and later, and Linux 64-bit
Key Features:
  • Supports flexible parameter customization settings.
  • The original quality remains untouched during the conversion process.
  • Retains original audio tracks for ripped Blu-ray discs.
  • Helps to selectively rip Bu-rays by detecting complete chapter information.
  • Efficiently rips unprotected DVDs and Blu-rays into several video formats.
WHAT WE LIKE
  • It is a free blu-ray ripper mac.
  • Rip Blu-ray to MP4, MKV, etc.
  • Support batch conversion.
  • Select audio tracks and subtitles in the video.
WHAT WE DON'T LIKE
  • Limited output options.
  • It does not handle encryption.
  • Beginners find it complicated to use.
  • Supports the live preview of only the first four minutes of the video.
HandBrake: free Blu-ray Ripper Mac
3. MakeMKV
MakeMKV is a trusted Mac Blu-ray ripper suitable for people requiring high-quality MKV output. It is trusted to remove some copy protection and rip Blu ray into a large MKV file. Since it lacks compression, you must either pair it up with another software for lossless compression or ensure your computer has sufficient file storage space.
💻Supported OS: Windows XP or later, Mac OS X 10.6 and later, and Linux x86 or amd64
Key Features:
  • Easy to use with free Beta support.
  • Rips Blu-rays without compromising on video quality.
  • Removes protection from Blu-ray discs and folders.
  • Converts seamlessly to MKV format.
  • Maintains original lossless quality when ripping Blu-ray discs and folders.
WHAT WE LIKE
  • Excellent output quality.
  • Allows free trial for full functions.
  • Retains metadata when rips Blu-rays.
  • Reads Blu-ray with protection of AACS and BD+.
WHAT WE DON'T LIKE
  • Supports only MKV formats.
  • Slow ripping speed.
  • Relatively large file size as it lacks compression.
MakeMKV: Free Blu-ray Ripper for Mac
4. Leawo Blu-ray Ripper for Mac
Leawo Blu-ray Ripper for Mac is another practical solution that helps Mac ripping Blu-ray without trouble. The software is powered with excellent decryption technology to remove common Blu-ray protection or region codes restricting you from copying the disc. It works seamlessly for 2D and 3D Blu-ray ripping and supports more than 180 audio and video formats.
💻Supported OS: Windows PC 7/8/8.1/10/11 and macOS 10.13/10.14.../13/14
Key Features:
  • Rip Blu-ray to MKV, MP4, and other 180+ digital formats.
  • Keeps 4K quality with original audio effects.
  • Several preset profiles are available.
  • Supports batch conversion for a speedy ripping process.
  • Easily removes most of the Blu-ray protection.
WHAT WE LIKE
  • Supports merging files, adjusting parameters,  and other custom options
  • No quality loss while ripping Blu-ray discs and folders.
  • Preserve Various Audio Options and Subtitle.
WHAT WE DON'T LIKE
  • Video quality loss after Blu-ray conversion.
  • Comparatively slower speed than other software.
  • Does not recognize ISO files and forced subtitles.
5. VideoByte BD-DVD Ripper for Mac
VideoByte BD-DVD Ripper is an efficient and intuitive Mac Blu-ray ripper that supports ripping all DVDs and Blu-ray discs whether they are protected. It has over 300 audio and video formats for an unparalleled conversion. Moreover, it preserves subtitles and audio tracks with lossless output. It has flexible parameter settings, a basic editing function, and advanced GPU technology that offers 6x faster speed.
💻Supported OS: Windows PC 10/8/7/Vista/XP (SP2 or later) and Mac OS X 10.7 or above
Key Features:
  • Easily removes encryption of commercial Blu-ray discs.
  • Converts Blu-rays into 300+ video and audio formats.
  • Enables adjusting video profiles with optimal settings.
  • Removes all protections and region codes.
  • Retains all subtitles and audio tracks.
WHAT WE LIKE
  • Supports 4K video output.
  • Rips Blu-ray at a fast speed.
  • Offer video editing features.
  • Supports to insert extra subtitles and audio tracks.
WHAT WE DON'T LIKE
  • The free trial allows the conversion of only 5 minutes of each video.
  • You must take a paid subscription to unlock all premium features.
6. VLC Media Player
VLC Media Player is a free Blu-ray ripper Mac with a basic ripping ability, making it a go-to choice for beginners. It is a popular ripping software with an easy-to-use function and decent output quality for most users. Earlier, VLC didn't support ripping protected content, but now it is equipped with a libdvdcss file that supports removing protection from a few Blu-ray discs.
💻Supported OS: Windows, Windows 64bit, ARM 64, all Mac versions, and Linux
Key Features:
  • Free and open-source software.
  • Keeps complete chapter information to rip with Blu-rays.
  • Offers a dozen profiles.
  • Handles numerous audio and video formats.
  • Allows to play, convert, and download media files.
WHAT WE LIKE
  • Blu-ray ripping function is easy to use.
  • Supports cross-platform availability.
  • Supports popular formats for selection.
  • Offers high video quality for ripped Blu-ray videos.
WHAT WE DON'T LIKE
  • It does not offer customization settings.
  • It does not rip most protected Blu-ray discs.
VLC:Free Blu-ray Ripper for Mac
Detailed Guide: How to Rip Blu-ray on Mac Computer?
In this part, we will take DVDFab Blu-ray Ripper as an example to show you how to rip Blu-ray disc, ISO file or Folder to digital formats on your Mac computer.
Step 1: Launch DVDFab Blu-ray Ripper for Mac and load Blu-ray disc/ISO/folder
Run DVDFab 13 and opt for the Ripper module. You can insert your Blu-ray disc into an external drive or simply add it through the 'Add button', or simply drag and drop the ISO file or folder onto the main interface.
How to rip blu-ray mac with DVDFab Blu-ray Ripper?
Step 2: Choose one profile and customize the output video.
Select your desired profile by clicking on 'Choose Other Profile'. Choose the titles, audio tracks, and subtitles to be included in the output video. You can also customize your output video via 'Advanced Settings' or the built-in 'Video Editor'.
How to rip blu-ray on mac?
Step 3: Start to rip a Blu-ray on Mac
Decide where to save your video on your hard disk drive or mobile device and click 'Start'. The process will then commence with detailed progress information displayed.
How to rip blu-ray mac?
Comparison of the 6 Best Blu-ray Rippers for Mac
Here, we have compared the six best Blu-ray rippers for Mac in various terms to help you compare them on some common factors and get a detailed understanding of each software. Let's look.
Input Output Blu-ray Decryption Quality Video Editor Audio/Subtitle  Speed Free or Paid
DVDFab Blu-ray Ripper for Mac Blu-ray/DVD discs, folders, ISO files 1000+ AACS, BD+, BD-J, Country Code, Cinavia, latest protected Blu-rays etc.  Lossless  Yes  Yes 50x fast speed Paid (includes free trial)
Handbrake
Blu-ray/DVD discs
MP4, MKV, and WebM
No
Fair  No  No No Free
MakeMKV
Blu-ray/DVD discs
MKV
AACS, BD+
Lossless  No  No No Paid (includes free trial)
Leawo Blu-ray Ripper for Mac  Blu-ray/DVD discs, folders, ISO files 180+ AACS, BD+, MKB, and CSS-DVD Lossy  Yes  Yes No Paid (includes free trial)
VideoByte BD-DVD Ripper Blu-ray/DVD discs, folders, ISO files 300+ APS, CSS, ARccOS, CPRM, AACS, BD+, and Cinavia Lossless  Yes  Yes 6x faster speed Paid (includes free trial)
VLC Media Player DVD/Blu-ray/CD MP4, MKV, WMV, etc.  AACS, BD+, BD-J, and Cinavia  High  No Yes No Free
Is it legal to rip protected Blu-ray discs?
Ripping your protected Blu-ray discs and folders is safe and legal if you use them only for personal purposes. However, you can face legal consequences if you rip it for any unfair use.
What is the best Blu-ray ripper for Mac?
Among many Blu-ray rippers available for Mac, we found DVDFab Blu-ray Ripper for Mac to be the best software, as it can rip into 1000+ digital formats in lossless quality and ensures a ripping speed of 50x to save you time. You also get a built-in video editor to crop, trim, and perform basic editing functions in your videos.
How to rip Blu-ray Mac with VLC?
You can rip Blu-ray discs and folders using Bluray ripping software Mac or VLC. Here are a few steps to help you with the process.
  • Step 1: Open VLC on your Mac computer and load the Blu-ray disc to rip.
  • Step 2: Tap the File menu on your Mac at the top-left corner and choose Open Disc.
  • Step 3: Select Disable Blu-ray menus and check Stream output.
  • Step 4: Tap Settings and go to Streaming and Transcoding Options.
  • Step 5: Select File, click Browse to input your save path, and name your rip file.
  • Step 6: Hit the Encapsulation Method option and select a preferred format. Then, set the transcoding options.
  • Step 7: Tap OK after finishing the settings. VLC will automatically start the ripping process.
The Bottom Line
By now, we hope you must have made up your mind to pick a suitable program considering the conversion speed, output quality, and additional features. When settling for one, ensure it not only checks all your needs but also brings some value to your decision. For instance, DVDFab Blu-ray Ripper is amongst the best Blu-ray ripper for Mac but is available for Windows users too. Moreover, its GPU-accelerated technology speeds up the ripping process, and a complimentary built-in video editor will save your storage space as you won't require a different video editor tool.
